Need Some Help/Infos
Discussion in 'General Subaru Discussion' started by kvue1989, Dec 30, 2015.
  1. kvue1989
    kvue1989 New Member
    MN
    Want to lowering my 2011 STi but not sure which spring/brand to go with. I'm lowering it for looks and daily use.
  2. JasonoJordan
    Set on springs or would you consider coilvers?
  3. blackozone
    Dirrty Souf
    Coilovers are a horribad idea for a DD that sees winter use. A good set of springs will be fine. Swift or Epic Engineering probably still make decent units for newer models. There may be better options.
  4. kvue1989
    kvue1989 New Member
    MN
    Sounds good thanks guys. I'm going with the Epic Engineering spring + flat black XXR-527 18X8.75 5x114.3 +35 wheels.
  5. SurlyOldManMN
    Apple Valley
    That's a bit wide for winter use. Plan on putting winter rubber on the stockers?
  6. kvue1989
    kvue1989 New Member
    MN
    I only drive the STI during spring, summer and fall. When it's winter I drive my beater.
  7. BeetsBearsBattlestars
    BeetsBearsBattlestars Well-Known Member
    Twin Cities
    DIRTY D likes this.
  8. SurlyOldManMN
    Apple Valley
    What are you going to do for dampers? Not a great idea to take the stockers (or any damper) out of their normal operating range... RCE has some really nice spring/bilstein combos. Given it's a dedicated spring/summer setup you might want to take a second look at coilovers, budget depending. Good springs/struts > mediocre coilovers.
  9. kvue1989
    kvue1989 New Member
    MN
    It will look similar to this with the Epic Engineering spring and wheels. But I'm going with the flat black.
    Photo 1
    Photo 2
  10. SurlyOldManMN
    Apple Valley
    You can get the visual impact with a number of combinations. Just know your stock dampers are going to wear out faster than a damper designed for the drop.
  11. kvue1989
    kvue1989 New Member
    MN
    What do you suggest? Which spring/coilvers.
  12. SurlyOldManMN
    Apple Valley
    I have an LGT so it's not exactly the same, but I've run a bunch of suspension setups. By *FAR* my favorite setup is KWv3's. No contest. Had I not wrecked a corner I'd be running those year round (with a sleeve to keep the grit out of the threads in the winter). I'm very happy with the bilstein and swift combo I'm running now; though I'd prefer the RCE blacks for a progressive setup which I feel is more appropriate for the road surfaces around here.
  13. kvue1989
    kvue1989 New Member
    MN
    I see I'll look into it thank you.
  14. webcrawlr
    webcrawlr Well-Known Member
    minneapolis
    Talk to Miles at RCE. They'll point you in the right direction.
    SurlyOldManMN likes this.
  15. JasonoJordan
    So if it sees no winter driving back to my original question..
    Ryan FailRad likes this.
