ok i jus bought a VF22 and i need to know any suggestions on what parts to buy, such as size of injectors, what kind of top mont, fuel pumps and any thing else i would need to make my car run with this turbo also wheres a good place to have my car tuned. my currents mods are ERZ up and down pipe, and invidia catless exhuast. Cobb stage2 reflash. thanks solomon
If you are strapped for cash then the SS Autochrome TMIC from ebay isn't a bad option but if you have money I say splurge on a little bit nicer one like the APS. Injectors, 730cc to 800cc should be fine. Walbro Fuel pump and you should also get an Inlet, perrin or samco or aps hard one, That stock one will kill you. As far as a tune goes, DB can do you just fine as well as the other shops (DB is the only one I have had experience with). The other option is to see if any of the OpenECU guys around here would be willing to tune you.
Injectors you will need to have ATLEAST 600cc and maybe more depending on how much you want to push things on pump gas. You will need to get a better tmic and a fuel pump. You will also want to install a new inlet pipe, but make sure you get a good one. I have heard alot of bad things about the cheap ebay ones sucking together. Other than that you are looking for a good tune. Russ
thanks guys...how much do the open ecu guys charge for the tune? and whats an estimate for a tune at db? also what type of feed would i need for the injectors? solomon
