Need Wastegate Work done...Who Does this in MN??
Discussion in 'Modifications And Maintenance' started by Ice, Aug 23, 2007.
  1. Ice
    Ice New Member
    20 Mins. from the City
    I got Boost Creep and a little Spiking going on right now and need to look at internal wastegate work or purchasing an external wastegate....Please help guide me to the right people for this around here!!! Thank You
  2. Justin
    Justin Well-Known Member
    St. Paul, MN
  3. Ice
    Ice New Member
    Where are you located and would this involve me removing the turbo and reinstalling it???
  4. Justin
    St. Paul, MN
    we are in st. paul, about a mile out of downtown. yes the turbo would have to come off.
  5. Ice
    Ice New Member
    I would like to use your services but I am not that mechanically inclined nor do I have enough time to do that myself right now. I am looking for a full service.
  6. Justin
    St. Paul, MN
    we are full service. we can take the turbo out, port it, and then reinstall it for you.
  7. w_o_t_boy
    w_o_t_boy Well-Known Member
    Seattle
    Are you sure you don't just need a better tune?
  8. Bullwinkle
    Saint Paul
    +1. What car & mods?
  9. Scuba Steve
    In the Co-Driver Seat
    justin, what's your turn around time on a port job and hotside coating? pm me....
  10. Justin
    St. Paul, MN
    generally we say about 10 days but lately its been around 2 weeks because we are so busy. however, if we know your car is out of commission we can bump it up our to do list
  11. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    weld the door shut and go external.
  12. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    wait? what turbo and what are your mods?
  13. Ice
    Ice New Member
    Car Details:
    2006 WRX 2.5L
    Original Turbo
    3" Full Turbo Back Perrin Exhaust
    Fully Tuned by DB Performance on Dyno with Stage 2 Maping(I Believe)
    Side Note:
    Right after tuned car ran great with mild Creeping only in 4th gear when
    flooring it from below 3500 RPMs
  14. Scuba Steve
    wastgate actuator arm adjusted?
  15. Ice
    Ice New Member
    Justin,
    Thats good news accept this is my daily driver and dont have a second car so I would need to get a rental so 2 weeks would cost me some ching...Let me know what ya think...Thanks
  16. Ice
    Ice New Member
    I havent touched anything on the Turbo/Wastgate etc.
  17. w_o_t_boy
    Seattle
    define boost creep.
  18. wall of tvs
    dream ftw
    That's not boost creep, it happens when the turbo dynamics tables aren't adjusted properly and don't open the wg enough since the turbo is being loaded for a longer period of time (since you are in a higher gear).
    By your rationalle, are you are getting "boost creep" in 2nd gear because you are seeing higher boost levels than 1st?!? Yet another tidbit of Nasioc hype that is untrue.
  19. Bullwinkle
    Saint Paul
    +1. Get a better tune, and read up on the definitions of boost spike and boost creep.
  20. Nuke
    Saint Paul
    boost creep is when boost is hiding and you can't hit boost, and then it jumps up and scares you, right?
  21. wall of tvs
    dream ftw
    yeah, and boost spike is when your turbo stabbs you in your sleep with an icepick to the forehead
  22. Ice
    Ice New Member
    Okay here is what is going on:
    Basically at this point whether Im in 1st, 2nd, 3rd, 4th, or 5th and I am
    accelerating below 4000 RPM nothing grabs just revs out untill I let off.
    What is odd is when I first got my car tuned it ran fine except for a little Boost
    Creep when in 4th or 5th gear and running low RPMs and then hittin the gas. Now
    over the past 2 weeks its gotten really bad to the point where I have to ease into every
    gear....SIDE NOTE I have read everything there is to read on NASIOC and yes that is why I came to the conclusion of Boost Creep and Spiking.
    Now Subie GURUS what are your thoughts??? Thanks
  23. Bullwinkle
    Saint Paul
    :crazy: I have no idea what you're trying to explain. WTF does this mean?
    Again, please re-read the definition of boost creep. There is a difference between hitting different boost in different gears (the result of 1 set of WGDC tables for all gears) and boost creep.
  24. Ice
    Ice New Member
    NOTE: I do not Have a Boost Gauge right now, but will get one.
    Maybe I do not have Boost Creep, but thats what my readings lead me to believe through my NASIOC readings. Basically what going on with my car is what I mentioned above. I guess I will do some more research and contact DB Performance who tuned my car and go from there. Sorry to waste your guys time. This is my first turbo car and my first car I have done mods to.
  25. curly2k3
    Silent Hill, Jackass
    what the crap, so you are assuming what the pressures are and you really have no basis for this thread?
  26. Ice
    Ice New Member
    Are you serious, no basis for this thread....there are other symptoms that can lead you to believe that you might have Boost Creep going on
  27. curly2k3
    ok, and have you even read what some of the most intelligent people here have said?
  28. Ice
    Ice New Member
    Yes, Have you even read what I have wrote. I just explained what was going on with my car above and that maybe I am off in my judgements. Listen Bud if you wanna argue or get into debates go and join TOASTMASTERS.
  29. fobiawrx
    fobiawrx Fabiola
    dont worry about it
    get some guys!
  30. curly2k3
    your a really snotty, pushy newb you know that? dont be a prick, you expect help and when its given you act like an moron, seriously. read their posts, go back on Nasioc or something and figure out what you THINK you are talking about first.
  31. Bullwinkle
    Saint Paul
    Ok. Please try to explain what symptoms you are seeing. I could not understand your previous post. You asked for help, so we're trying to tell you what additional information we need to help you.
  32. curly2k3
    i still dont see why he thinks its spiking or creeping, and if he read everything on nasioc like he said i am pretty sure one of the million actuator arm adjustment threads came up... whether he read them or not is questionable, but even still, sounds normal to me. i would say some fault in the tune or just imagination at work since you have no boost gauge even to backup your thoughts about it.
  33. Nuke
    Saint Paul
    I think you're catching this thing call torque...hehehe
  34. Justin
    St. Paul, MN
    so i'm assuming you are running logs to see what your boost is actually doing since you dont have a boost gauge ?? you obviously are getting boost numbers from somewhere right?
  35. curly2k3
    we would hope
  36. Zombie
    Zombie Well-Known Member
    nub .
  37. TSTRBOY2004
    why dont you just take someone for a drive and show them.... quit the pissing match and take advice...
  38. w_o_t_boy
    Seattle
    Its good that you're reading, but you have to take everything you read on NASIOC with a grain of salt because 90% of the people on there are morons.
    Anyone who's on here berating a stranger for not knowing what boost creep is wasting their own time.
  39. w_o_t_boy
    Seattle
    Did you get your car tuned when it was hot out?
  40. Ice
    Ice New Member
    Yes I did and I have noticed these changes ever since we have been having the milder temps around here.
  41. Ice
    Ice New Member
    What happens is no matter what gear I am in and if I am running low RPMs in that gear and then give it gas not even stomping on it my RPMs quickly red line or just jump up...Its almost like its completely bypassing something or missing something. It just doesnt grab anything, meaning move the car forward. I have to ease through every gear in order for me to gain speed right now. Does this make sense to you what I am explaining. I am planning on taking someone for a ride in it. It could very well need some more tuning. Thanks
  42. tangledupinblu
    MNBugeyeMafia#001
    Sounds like the clutch is going.
    But mine has also been doing something wierd like that. Well, not exactly. When I am in 3, 4, or 5 and at low revs, then apply gas, the car bogs and the rpm's don't increase at all like a misfire. Then I down shift and ease into it and it goes fine? I'm signing up for Wyo Tech dammit.
  43. Ice
    Ice New Member
    Okay...After some more reading and looking and taking your suggestion into consideration that could be what it is "Clutch Slipping"....See Shane at DB Performance said when I left after getting my car tuned by him to keep my eyes open for Boost Creep and he explained that without having a Boost Gauge one sympton would be the RPMs sky rocketing so naturally when this happened I looked up Boost Creep and I had similar symptons going on as explained in all the FAQ's but now Im starting to believe it could be my Clutch Slipping. I have smelt the clutch burning some occasions. Thanks for your suggestion!
  44. wall of tvs
    dream ftw
    Your clutch is toast.
    /thread
  45. Bullwinkle
    Saint Paul
    :+1:, sounds like it.
