Network (CAT6) or Telephony guy?
Discussion in 'Off-Topic' started by asujosh1, Oct 20, 2009.
  1. asujosh1
    asujosh1 Member
    Downtown Mpls
    I have a loft downtown that was run with CAT6 instead of phone lines so that they could later be used for network connections, but I dont know how to get my router connected to the punch-down block so that I can hook a computer up to the wall and get on the internet.
    Anyone know how to help and willing to stop in? I will buy the beer! :biggrin:
  2. Vector
    Vector Rally Organizer
    Can't stop by, but if you can post photos i can tell you what to put where.
  3. Ctracey218
    Duluth (MNBugeye Mafia #218)
    Time for some CISCO phones
    voip voip voip voip lol
  4. asujosh1
    asujosh1 Member
    Downtown Mpls
    here is a photo of the punch-down block
  5. Vector
    Ok, in that picture those lines are all punched down to a phone distribution block, which means they're all attached in parallel.
    The cable can be used, but that punch down can't.
    You have a couple of options. You can pull the cable (or cables if you're doing more than one) off of the punch down and reterminate them with an RJ-45 jack, or you can get an RJ45 patch panel (that panel looks like it'll take On-Q modules, so you could get one at Menards), and run patch cables from the patch panel to the router.
  6. asujosh1
    asujosh1 Member
    Downtown Mpls
    Will I need any special tools to use an 'On-Q module' with an RJ45 patch panel?
  7. asujosh1
    asujosh1 Member
    Downtown Mpls
    K, I'm headed to Menards, I'll see what I can find..
  8. predavore
    predavore Well-Known Member
    Southern 'Burbs
    CISCO = crap
  9. asujosh1
    asujosh1 Member
    Downtown Mpls
    K, I purchased this [​IMG]
    but I didn't get the block, just the jacks. Now I just have to figure out which one of those goes to the room that I am working in...
  10. predavore
    Southern 'Burbs
    That should work. Now just punch it down.
  11. asujosh1
    asujosh1 Member
    Downtown Mpls
    Anyone got one of those beepy-thingies that tell you when you have the correct cable?
  12. predavore
    Southern 'Burbs
    I have all that. I just called you and left a message. I'll be done here in 5 minutes.
  13. john
    john Well-Known Member
    Hudson
    *koff koff*
  14. asujosh1
    asujosh1 Member
    Downtown Mpls
    Thanks Predavore for giving me the hook up! Works great!
  15. subynate
    subynate Well-Known Member
    behind a welding hood
    but the magic jack is only 19.95 a year!
  16. Shibbs
    Pfft. Ya'll are wack. CISCO is great, its just getting way to snobby is all.
  17. Mr. Derek
    Mr. Derek Well-Known Member
    Princeton
    I used to machine the inner cases for Cisco routers so I know that part is quality ;)
  18. Bullwinkle
    Saint Paul
    Now I'm curious, what does this mean and what was your final solution? You just terminate them with some RJ-45 caps?
  19. asujosh1
    asujosh1 Member
    Downtown Mpls
    He put phone lines coming out of the punch block with RJ-11 connectors and then hooked the On-Q connectors up to the lines going to each room. I can now hook an RJ-45 connector up to the On-Q connector and have network connectivity in each of the rooms in the loft. Pretty sweet!
    Oh yeah, and if I want to remove the whole setup, I can just plug the RJ-11 into the connectors he put on the block.
  20. readymix
    Eloh, El
    I would have done an 8 port switch instead of that hub. Especially since you are using Cat-6, I would have used a gigabit switch, may as well make the most of it.
    In our house, I ran Cat-6 lines from all the main and lower level rooms to a 24port gigabit switch, transferring files within the house on teh wired network takes seconds. I used an old crappy netgear wireless router setup as an access point for wireless computers like the laptops and such, and wired all of it to a Cisco 1761. If I wanted to do phone through the 1761, I could. But when was the last time anyone used a land line?
  21. asujosh1
    asujosh1 Member
    Downtown Mpls
    I wasn't trying to make the optimal setup, I just wanted to make what I had work.
    Besides, I only have 3 jacks in the house, and only 1 will be used at any given time. The 4 ports on the wireless router cover the home theater machine, the PS3, and the office with one available port. Connections on the wired network are silly-fast.
  22. predavore
    Southern 'Burbs
    Yeah, no problem. I was a block away. Easy to do.
  23. sneefy
    sneefy Well-Known Member
    And...what do you prefer? 3Com?
    Cisco > *
