new guy
Discussion in 'The Welcome Mat' started by deathwish, Mar 1, 2010.
  1. deathwish
    deathwish New Member
    st paul
    hey my name is jordan i am looking at picking up an 05 wrx tomorrow im from st paul and this will be my first subaru and yea hope to see you guys out there
  2. thunderdan1313
    thunderdan1313 New Member
    minnetonka
    welcome
    any plans for the car?
  3. deathwish
    st paul
    im thinking sti wing, fmic, exhaust, and cobb i used cobb on my rx8 and i liked it so ill go with them again then eventually lower it
  4. thunderdan1313
    minnetonka
    cobb exhaust or a cobb AP
  5. deathwish
    st paul
    ap sory i didnt specify
  6. retreif
    Somerset, WI
    Check out the open source solution. OpenECU. Spend the money on something that actually increases performance.
    Welcome!
  7. Tim the Plumber
    Bloomington
    just some advice take it how you want, but Open ECU custom tune is gonna cost less then a cobb AP and will get you better gains IMHO but congrats on the new car! hope to see you out at some meets!
  8. thunderdan1313
    minnetonka
    Brian Shorten:
    Cobb AP maps are "off the shelf" maps, meaning instead of being tailored to your car, they are a "safe" map that will work on a number of cars with similar mods. You won't be able to develop as much power, as Cobb has to adjust timing and fuel in the interests of not getting sued because their map contributed to a motor failure. An open source or dyno tune will be tailored to your car and your mods, and you can decide how close you want to run to the ragged edge of the power vs. reliability envelope. And with the money you spend on an AP and then getting it protuned to what you want, you could have several OS tunes.
    for the price of a used AP($350) i got an dowpipe an openscource toon from NUKE. NUkE's stage2 toon on my car(o5lgt wagon) is a faster ,smoother toon than my buddy how has an 05STI cobbAP stage2.
  9. TheSnowman
    TheSnowman Well-Known Member
    Twin Cities MN
    hi beecham this is ilii
  10. deathwish
    st paul
    thanks guys for the info im gonna have to look into it more
    hi illi!
  11. john
    john Well-Known Member
    Hudson
    Welcome aboard, and +1 on the opensource tune.
  12. Bullwinkle
    Saint Paul
    Yup.
    And stay away from a FMIC on the stock turbo.
  13. deathwish
    st paul
    im curious as to why i would want to stay away from fmic? im just tryna learn
  14. Lowrider
    Lowrider Well-Known Member
    C'mon who cares?
    deathwish------> Don't let the 05 Kill you....hahaha
    Welcome!
  15. TheSnowman
    Twin Cities MN
    not much gain...
  16. deathwish
    st paul
    haha ill try not to let it kill me
    gotcha well i wanna upgrade the turbo eventuially also so mabye i will just wait till i get a turbo for a fmic
  17. readymix
    Eloh, El
    Yeah, I would wait till you upgrade the turbo to get an FMIC. Smaller turbos like the TD04 that come stock on the WRX are going to be running out of breath already in higher RPMs on the 2.0L and the 2.5L, which is why you see alot of stock turbo tunes taper off at higher RPMS, the engine is demanding more input air volume than the turbo can produce in the higher RPM range. By adding tons of FMIC piping, you are adding to the amount of volume that the turbo has to pressurize to reach efficient pressures. Think of your engine's intake cycle like a balloon. When the piston is on the downstroke on the intake cycle, it has to draw in air to fill the cylinder. The turbo is there to aid in filling and, as it turns out, pressurize that air above atmospheric pressure. In a topmount configuration, the turbo has to pressurize the cylinder, and the intercooler core, and any piping in between the turbo outlet and the cylinder. By adding all that piping to the system, you are creating a much larger amount of volume that needs to be pressurized. What the longer piping does is creates a lag time to efficient pressure. With larger turbos, that lag time isn't as much of an issue due to the larger CFM being moved by the turbo, the system fills faster and the time to fill is shorter.
    Cliff's Notes: Wait for the FMIC till you are running something larger. I think a nice, larger topmount will suit you, even up in the 20G turbo territory...it'll definitely give you that speedy, torquey, insta-spool that the TD04 on the topmount is good for. Beyond the 20G you might want to start thinking about an FMIC. I'd get your goals sorted before you start making those decisions. It's best to make a goal, and then build your system around that. Read around the FAQs and Newbie info section of the site, it has lots of information. But your first order of business before modding should be to decide what it is that you want your car to accomplish for you, then build the car to suit those needs.
  18. deathwish
    st paul
    thanks that makes sence i really didnt think it mattered that much but after reading that i think i will just stick with a top mount
  19. seal
    seal Member
    Bloomington
    welcome
  20. Randy_Marsh
    Randy_Marsh Member
    Columbus, MS
    Sounds like a good plan man, good luck and drive safe!
  21. MMC_555
    MMC_555 Well-Known Member
    Someplace
    Welcome, and take a look around there's plenty of TMICs to choose from... Even then, there may be other mods you might think about before an IC.
    My 0.02...
    -deleted. Missed the dates got carried away/confused by the scammer
