Next WRX to use Electric Turbo?
Discussion in 'General Subaru Discussion' started by Bryan, May 3, 2012.
  1. Bryan
    Bryan Member
  2. ofspunk7
    Interesting. I know Porsche has a version of this in one of their cars. The new M3 is also said to have 3 turbos. Two of which would be your typical exhaust turbos and one electronic. There must be some benefit to it!?!?!
  3. Nater
    Nater Member
    using the current heat from the exhaust of a car > some gizmo to create energy from that > to run an electric turbo?
    interesting....
  4. idget
    ^It's basically a turbine/generator connected to an air compressor.
    So less/no lag, better form factor (the compressor and the turbine don't need to be physically mated together), more efficient, potential to eliminate alternator, etc...
    The big downside at first will be the aftermarket support. It'll take a while for the aftermarket to catch up (and be reasonably priced) to the point where you can easily get a more powerful generator, a bigger compressor, or both.
    edit: http://en.wikipedia.org/wiki/Hybrid_turbocharger
    http://green.autoblog.com/2010/08/3...ustries-develops-hybrid-turbocharger-to-gene/
    Nater, I think this is what you're describing:
    http://www.3k-warner.de/products/eBooster.aspx
  5. J.Rex
    J.Rex Well-Known Member
    I tried boosting my old civic with a turbine from an electric RC airplane. It didn't work, then the plastic prop fell off and went through the engine. I was young and dumb at the time.
    It would be cool to see fhi do something electric though, you would actually be able to use boost in an Autocross or rallyx then.
  6. atacamaR
    atacamaR Well-Known Member
    haha, nice. using this in my signature on swedespeed for a while if you don't mind.
    arsenal741 and Slopestyle1 like this.
  7. Shane86
    Shane86 Well-Known Member
    Combine it with a regenerative braking system, and that could add a fun little boost coming out of a corner :)
