no spark, ideas?
Discussion in 'Modifications And Maintenance' started by AWDimprezaL, Mar 13, 2007.
  1. AWDimprezaL
    well my car died, cranks bu no spark, so far brian and i have tried coil, cam and crank sensors, and ignitor, anyone else have any ideas?
  2. tangledupinblu
    Online
    Does the L have an ignition module? Had one that gave me similar problems, but was on a ford/lincoln.
  3. Aegis
    I had this happen on my Mazda, we tried everything before I pulled off the timing belt cover and yanked out the belt ...
    The good news is, I had said it was timing the whole time, so I wasn't the one who looked like an ass ;)
  4. AWDimprezaL
    it cranks like it has compression, it just doesnt have spark, has no codes either...hmmm
  5. Iroc-Z
    Iroc-Z Well-Known Member
    Could I get a little info on the car?
  6. AWDimprezaL
    1996 Impreza, 2.2 liter 5mt, our master techs our looking at it now.
  7. Dynapar
    try the igniter. it the little black box mounted above the pitch stop. that thing tells your car when to fire.
    do you have spark leaving the coil pack? maybe try looking for faryed wires between the igniter/coil/sensors and the ecu. or try another ecu.
  8. AWDimprezaL
    i have a weak pulse going to the coil pack, ive tried a different igniter.
  9. Aegis
    see, you just need to get it good and drunk, and those sparks are sure to start flying again :biggrin:
  10. AWDimprezaL
    unfortuntly im leaning twards ecu
  11. w_o_t_boy
    w_o_t_boy Well-Known Member
    Fix it with an ej25 swap.
  12. AWDimprezaL
    would still need to find somthing to make vroom vroom
  13. Dream
    boost, it finally got the best of your little 2.2 :p :biggrin:
  14. AWDimprezaL
    yeah the boost must have blown the spark out ;)
  15. Dynapar
    go MSD ignition and let 'er buck. w/a stand alone ignition system you should get plenty of spark ;-).
    have you tried a different ecu? maybe yours hit the wall with all this logic learning stuff, old dog new tricks ya know.
  16. AWDimprezaL
    i hope its not the ecu, but it would be nice to know if it actually is or isnt
  17. wall of tvs
    your logic module ran out of logic
  18. ShortytheFirefighter
    Trunkmonkey on strike?
  19. AWDimprezaL
    ITS ALIVE! loose connector at the main harness w00t for that. also w00t for this little car
  20. 6MTizzle
    6MTizzle 2SLO
    Sweeeeet! FrankenL lives!! I was worried.
  21. AWDimprezaL
    you cant kill this car.
  22. Sogonerg
    Sogonerg Anteater
    ^Her name is "Christine" and she's RED hawt
  23. 6MTizzle
    6MTizzle 2SLO
    yes cup. no engine management ftw.
  24. Aegis
    ATHF references make me smile..:biggrin:
  25. AWDimprezaL
    well since we cleared the memory its running like poo...but it usually does after its cleared, even when it was n/a oh well, waiting game.
