Noise coming from wheels?
Discussion in 'Modifications And Maintenance' started by 763WRX, Apr 17, 2007.
  1. 763WRX
    763WRX Well-Known Member
    Im having some squeaky noise coming from my wheels (wheel area not sure where) and don't really know what it is. The car is a STI any info as to why my wheels squeaks would be appreciated. Thanks.
  2. Dynapar
    it could just be your brakes squeaking. does the sound change with speed or braking, or turning?
  3. TSTRBOY2004
    mice in your wheel wells??
    bearing? brake pad squeek?? check thickness left on pad could be the indicators squeeking... its called the idiots warning to say "hey look at me - I need new pads".... ha ha ha
    could be a number of things... but check the pad level first because wheel bearings usually make a whirrring type noise first... my vote - you NEED new pads..
  4. curly2k3
    hey, not always idiot warning tho either, my pads are still like new, but they squeek and squeel like no ones business! but yeah, probably pads, not the right sound for wheel bearings. do the brakes pulse at all or are the rotors still good and gravy?
  5. hella_sti
    hella_sti Well-Known Member
    sounds like a wheel bearing, they'll go out pretty quick if you're on the brakes hard and it'll transfer the heat from the rotor hats to the knuckle's bearings.
  6. WRX1
    What kinda of rim and tire package are you running??
  7. Dynapar
    from what i have gather wheel bearings make a howling sound, which is very distinct. if it is just a squeak it could be 100+ things. i would put wheel bearing at the end of the list. it could just be some dust/dirt in the pads that will work it self out.
  8. 763WRX
    Yes the sound does sometimes change when im driving at different speed, usually at lower speed 20-40 mph and sometimes makes a rubbing or grinding noise when im turning usually when I make right turns. I have on Stock STI BBS rims with all season Michellin Pilot Alpin tires.
