not hitting target boost after mod...
Discussion in 'Modifications And Maintenance' started by vanddelor, Oct 4, 2007.
  1. vanddelor
    vanddelor Well-Known Member
    ok...i have stage 2 wrx running on xpt stage2 map...
    now, after installing a prosport elect boost gauge alone...it was showing i was hitting between 16-17(almost 18)lbs....which is normal from my past logs...
    and then after installing a prosport elect egt gauge, i'm not even able to hit past 15lbs (according to the boost gauge)
    when installing the egt...i had to tapped into the mani...i'm pretty sure this wont even bother boost...i've checked for boost leaks everywhere...
    could it be just that my boost gauge is shot already..??...i've just got it for like a week...
  2. webcrawlr
    webcrawlr Well-Known Member
    Run a log, see how accurate it is.
  3. Nuke
    yes, it might be your boost gauge
    grab a log
  4. WRX1
    Well, you could have a pre-turbo leak since you HOPEFULLY removed the manifold before you drilled and tapped the hole. If you drilled and tapped the mani on the car, you could have damaged the turbo with the metal shavings. But still pull a log.
  5. Bielke55
    New gaskets at headers after install?
    New gaskets at Up pipe?
  6. vanddelor
    i did pull a log and everything seems normal(compared to my other logs)...and yes..i took the mani off the car when drilled...would it be that the boost gauge needs a break in period to work accurately..??...(just a thought)
  7. vanddelor
    no..the ones i took off looked perfectly new...and plus..i checked the for leaks before i put on the mani heat shield and there was none...
