Nuke infected STi!!!
Discussion in 'Photo & Video Gallery' started by asiandude, Jun 28, 2011.
  1. asiandude
    asiandude Well-Known Member
    '05 STi
    Invidia DP with stock catback
    800cc sidefeeds
    DW 300 fuel pump
    E85 Nuke Tooned
    Ran at BIR this last weekend at the MAP event. Low traps because I didn't shift into 5th gear. I just rode out 4th past the line.
  2. Nuke
    Saint Paul
    LOL what's up with that
    That does not look right at all
  3. Lowrider
    Lowrider Well-Known Member
    C'mon who cares?
    I see some sort of consistency...where is the wrong?
  4. predavore
    predavore Well-Known Member
    Southern 'Burbs
    Seems slow.
  5. Moleness
    At work or in the garage
    Should have grabbed 5th...at like 6500rpm long before the line.
  6. blackozone
    Dirrty Souf
    Looks like sandbagging. Working on your hustle?
  7. WREX
    WREX Member
    At your girlfriends house.
    I also thought it kind of off. My wrx will run around a 14 flat stock. Seems kinda slow for a tuned STI. No offense
  8. Nuke
    Saint Paul
    Lol, i think everyone should look at the modlist one more time ;)
    The owner should know what's hurting him
  9. WREX
    WREX Member
    exhaust! Get some!
  10. Nuke
    Saint Paul
    Huge restriction. Barely pushed 19psi
  11. WREX
    WREX Member
    wow. It has so much more potential. Can't wait to see him get a good exhaust system and run some more 1/4 mile times.
  12. asiandude
    I will be going back to BIR this weekend. Going to break into the 12's I hope. Going to try some different shifting points.
  13. Nuke
    Saint Paul
    Lol 12.99
  14. WREX
    WREX Member
    did you upgrade your exhaust yet? seems kinda pointless to spend the money at BIR to maybe pick up a couple tenths with the same set-up. I doubt you will gain tons of time buy changing shifting points. just my .02
  15. asiandude
    This time around im going be using lc and shifting to 5th gear. Ill post up my times. I don't think it waste of time if your having fun doing what you do.
  16. WREX
    WREX Member
    Never said it was a waste of time, but going back to the track without any upgrades from your last set up? You gotta know that your stock exhaust is hurting more than helping. I know its fun, I used to drag an old heavy muscle car years ago. But I always liked to come back to the strip with another "go faster" part installed. That's was the real fun is to see what you did to the car to make it faster.
  17. asiandude
    I will be running a aftermarket catback and retune. Hoping for some way better times.
  18. WREX
    WREX Member
    and you'll get to with a good exhaust system on there. let er breathe!
  19. Nuke
    Saint Paul
    can't wait to push power!
  20. Juks
    Juks Well-Known Member
    Prior Lake
    Definately pick up an exhaust. I was running 12.7 with my STI on pump gas when it was stage 2. E85 should put you below that for sure.
    You can prolly find something for cheap in the for sale forums...3" catless is all you need.
