OBDII Scanner recommendation
Discussion in 'Modifications And Maintenance' started by Gspot, Aug 25, 2004.
  1. Gspot
    Gspot New Member
    I want to buy a scanner for my laptop. I'm just gonna use it to pull codes every now and then to make sure my CEL is just the stupid misfire code. I'd like a universal one to use on other people's cars too. Also do they pull OBDI codes too? Anybody have any recommendations? Lets put a cap at $150, though.
  2. WRX1
    Over there
    http://www.obd-2.com/
    Thats where I purchased my scan tool from. I have had good luck with it, and you get free software updates.
  3. kickin_81
    kickin_81 Well-Known Member
    St. Paul
    There was a recent thread about obd-2 scanner recommendations. I have wanted one, but I never went ahead to fully do a comparison and purchase one. There's plenty out on the market, but the more expensive ones offer more features and convenience.
  4. Zola
    Zola Well-Known Member
    St Louis Park
    Yeah but he wants one to hook up to his laptop, that narrows the field quite a bit I think.
  5. igofast
    igofast New Member
    St. Cloud, MN
    I went for the one off of www.obddiagnostics.com. I went with that one because a)it's cheap and b)it supports all OBDII interfaces(PWM, VPW, and ISO).
    I like the software on Russ's unit much better. This software isn't as well developed, it doesn't even cross referance trouble codes.
  6. Gspot
    Gspot New Member
    are there any that can read OBDII and OBDI? John, that will probably be advanced enough for me to pull and clear codes though, right? Does the software contain definitions for all the different codes?
  7. igofast
    igofast New Member
    St. Cloud, MN
    Yeah, it does great to pull codes, reset the CEL, it will even do freeze frame data(shows when your CEL went off). It can also display a dashboard with guages that update no-so-often. It has all the P codes in the help files, but you have to find the code yourself.
  8. WRX1
    Over there
    obdII is a universial interface, and obdI is per manufacture. That means for obdI ford, chrysler, and gm all have different plugs. ObdII is the same for all cars. The only way to get obdI and obdII is go with the $400 auto xray system that includes all the cable and such.
