Official Final Project Thread
Discussion in 'Off-Topic' started by Paul Revere, Dec 15, 2007.
  1. Paul Revere
    So as a student in the fluid power program at Hennepin Tech I have to build a final project by the end of the up coming semester. My first thought was to make something small and unique. So I set my mind to thinking of how to make a RC car with a pneumatic or hydraulic transmission. Not wanting to make the car any bigger than a 1/10th scale RC car i soon realized that it would have to be much bigger than I had originally planned. That being determined I started working on bigger and better plans for this RC car ... that is until yesterday.
    I was talking over project ideas with my instructor and a classmate. When my classmate brought to my attention that he has a donor go-kart that we could put a hydrostatic drive on. My immediate thought was to make it FAST! So I pondered the idea and went to work for the day, after a quick phone call I found a donor engine (a 1985 Kawasaki KLR 600). A friend of my dad and I has had it laying around for a bit and said it was mine to have. Next the chassis, now I didn't wanna spend a ton of money on this project so I turned to someone who knows the karting world. Not knowing what to expect I was all out stunned when I was told that he would give me a slightly tweaked kart frame.
    So know it all begins I have what I believe to be the two most expensive pieces of my puzzle, and best of all they were donated. I will keep you all up to date on my project and if anyone would like to help feel free to lend advise or a helping hand.
  2. AWDimprezaL
    it should rip! the klr is a torque monster
  3. Paul Revere
    Well if everything works I should be able to have the engine sit at a steady RPM and then stroke the hydraulic motor, the kart should have serious torque. If all goes well the KLR engine might even see boost ???
  4. AWDimprezaL
    dont boost an air cooled carbed single cyl!
  5. Paul Revere
    Liquid cooled and I said might ... can you imagine 3500 constant RPM and 4-6 psi? I also don't know if I should run a sold rear axle with single hydraulic pump powering it, two individual pumps at each wheel, or 4 pumps one at each wheel?
  6. fobiawrx
    fobiawrx Fabiola
    dont fail... boost it
  7. Paul Revere
    I came across an issue today already, to couple the gas engine and hydraulic motor together I wanna use sprockets and a shortened dirt bike chain. On the other hand my instructor says that the force of the engine spinning 3500-7000 will wanna throw the chain right of the sprockets. I would need a tensioner, but what kinda roller tensioner would hold at 7k??
  8. tangledupinblu
    Motorcycle belt drive?:dunno: Like the ones they use at O.C.C.:p
  9. Paul Revere
    Well I was thinking a 520 chain would hold up just as well. On the plus side I could make that whatever length I needed.
  10. Paul Revere
    My instructor sorta explaining the idea ...
    His son's home made hydrostatic motorcycle ...
  11. Paul Revere
    151 views and no one has any idea's??
  12. Paul Revere
    Does anyone have any experience with making gearing reduction?
  13. TSTRBOY2004
    it's YOUR project... we dont get credit for it
  14. curly2k3
    yeah if this is YOUR final project, YOU should be doing the work for it.
  15. Mike Wagner
    Mike Wagner New Member
    If this is a Kart use an axel clutch, they are incredible.
    They are set up for belt or chain.
  16. Urabusvids
    Urabusvids Well-Known Member
    Which hennipen tech do you go to?
