oil leak.
Discussion in 'Modifications And Maintenance' started by Squiggly, Jan 19, 2008.
  1. Squiggly
    Squiggly Squiggly
    i just noticed a significant amount of oil in my drive way. both the filter and plug were checked and tight. i dont have access to a garage tonight and its to cold outside to check things out.
    anyone know what the potential problems could be?
  2. AWDimprezaL
    head gasket, oil pump seal/crank seal, valve cover gaskets
  3. driftin240
    driftin240 Well-Known Member
    Erik got you covered on that. Probably the left (drivers) side head gasket. The colder it gets, the more we see!
  4. Squiggly
    Squiggly Squiggly
    what that gonna cost me. parts and labor incase i dont wana do it myself.
  5. Squiggly
    Squiggly Squiggly
    BUMP. anyone?
  6. curly2k3
    Search it man, i know Ryan just did this and commented on using STI gaskets or something along those lines
  7. Squiggly
    Squiggly Squiggly
    ok change of situation. i inspected the engine bay and saw fluid all around the power steering area. i then checked the fluid on the ground and it appears to be PS fluid.. YEY.
    if its around the resi. then it wouldnt be a pump would it?
  8. Squiggly
    Squiggly Squiggly
    just turned the car on to let it run and the PS resi started to overflow and bubble out of the cap
  9. AWDimprezaL
    hmm very interesting, maybe it was the whole time you had it disconnected the rack got f'ed over
  10. flstffxe
    flstffxe Well-Known Member
    the pump may be just unable to pump the fluid do to it being fricken cold out right now. It is more then likely just agitating the fluid causing the bubbling you see. once the fluid warms up it should go away, you could also try a synthetic fluid. See if the pump is better able to move the synthetic in the cold weather.
  11. Ryan
    Ryan Sled drifting master
    hehe, you're lucky it's not your headgaskets. That is NOT something you want to attempt yourself, unless you know what are you are doing and have the magical subaru tool.
  12. Shibbs
    Yeah, as mentioned my guess is frozen power steering fluid. Ever had it flushed? Take it to a shop and have your PS fluid flushed. Not that spendy, if I remember correctly.
  13. bikerboy
    Hope you all know that Subaru's do not use power steering fluid? Subaru requires you to use ATF fluid.
  14. curly2k3
    i use whatever is not listed on the cap. (reference to the engine oil thread)
  15. AWDimprezaL
    i would suggest using the new HP trans fluid, we have plenty in stock and its a synthetic fluid
  16. Squiggly
    Squiggly Squiggly
    how much would i need and how much is it?
    also the problem seemed to wain itself out but i still want to change the fluid after the scare.
  17. AWDimprezaL
    idk 2 qts at under 10 bucks each
  18. Squiggly
    Squiggly Squiggly
    k sounds good. ill prob swing out there on thursday
