ok for us noobs that don't know all the abreviations
Discussion in 'General Subaru Discussion' started by Torc, May 21, 2006.
  1. Torc
    Torc New Member
    i found this..helped me a ton
    Basic Terminology & Acronyms
    4EAT – Four Speed Electronic Automatic Transmission
    5MT – Five Speed Manual Transmission
    5EAT – Five Speed Electronic Automatic Transmission (includes Sportshift)
    6MT – Six Speed Manual Transmission
    ABS – Anti-lock Braking System
    AFR (or A/F) - Air to Fuel Ratio
    ALK - Anti Lift Kit
    ALS: Anti Lag System (EM trick to keep the turbo spooled when off the throttle)
    AT – Automatic Transmission
    ATF – Automatic Transmission Fluid
    AutoX – Autocross
    AVCS – Active Valve Control Sysem
    AVLS – Active Valve Lift System
    AWD – All Wheel Drive
    AWHP - All Wheel Horse Power
    BBK - Big Brake Kit
    BHP – Brake HorsePower (measured BEFORE transmission)
    BOV – Blow Off Valve
    BPV - By-Pass Valve
    CAI – Cold Air Intake
    Cat – Catalytic Convertor
    Catback -- Catback (after the Catalytic Converter) exhaust section
    CBE = Cat Back Exhaust
    CEL – Check Engine Light
    CF – Carbon Fiber
    Cf -- drag coefficient or coefficient of drag (airflow resistance)
    CO2 – Carbon Dioxide
    Diff – Differential
    DP -- Down Pipe
    DC -- Double Clutch
    DCCD -- Driver Controlled Center Differential
    DOHC – Dual Overhead Camshaft
    DRL = Daytime Running Lights
    EBC – Electonic Boost Controller
    ECT - Electronically Controlled Transmission
    ECU – Electronic Control Unit (engine control unit)
    EFI – Electronic Fuel Injection
    EG – Subaru 6-cylinder engines (up through mid to late 90’s)
    EG33 – Subaru 3.3 litre 6-cylinder engine code (SVX)
    EGT - Exhaust Gas Temperature
    EJ – Subaru 4-cylinder engines (early 90’s and newer)
    EJ20 – Subaru 2.0 litre 4-cylinder engine code
    EJ205 – Subaru 2.0 litre turbo engine (US WRX)
    EJ22 – Subaru 2.2 litre 4-cylinder engine code
    EJ25 – Subaru 2.5 litre 4-cylinder engine code
    EJ255 – Subaru 2.5 litre turbo engine (US Forester XT, Baja Turbo)
    EJ257 – Subaru 2.5 litre turbo engine (US WRX STi)
    EZ – Subaru 6-cylinder engines (post EG series H6 engines)
    EZ30R – Subaru 3.0 litre 6-cylinder engine code (BL/BP Legacy and new Outback)
    EMS = Engine Management System
    FDR - Final Drive Ratio
    FMIC – Front Mount Intercooler
    FWD – Front Wheel Drive
    FSB -- Front Sway Bar
    H4 – Horizontally Opposed 4 cylinder (boxer)
    H6 – Horizontally Opposed 6 cylinder
    HID – High Intensity Discharge (headlights)
    HT-- Heal and Toe
    IC -- Intercooler
    JDM – Japanese Domestic Market
    LHD = Left Hand Drive
    LSD – Limited Slip Differential
    MAF or MAS – Mass Air-Flow Sensor
    MAP – Manifold Absolute Pressure Sensor
    MBC – Manual Boost Controller
    MIL – Malfunction Indicator Lamp (CEL)
    MT – Manual Transmission
    MY – Model Year
    NOS - Nitrous Oxide
    OBD - On Board Diagnostics
    OE – Original Equipment
    OEM – Original Equipment Manufacturer
    Pinks --certain STI parts... springs, swaybars, injectors, timing belts. Due to their color.
    Pot -- (ie. 4-pot brake) pistons on caliper.
    P&P -- port and polish of cylinder heads to improve airflow.
    RallyX – Rallycross
    RHD = Right Hand Drive
    RPM - Revolutions Per Minute
    RSB -- Rear Sway Bar
    RWD – Rear Wheel Drive
    SOA – Subaru Of America
    SOHC – Single Overhead Camshaft
    SPT = Subaru Performance Tuning
    SWRT = Subaru World Rally Team
    STi (pre-06) / STI = Subaru Technica International
    TMIC – Top Mount Intercooler
    TBE -- Turbo Back Exhaust
    TR - Tuner Ready (aka '06 WRX TR)
    TSB - Technical Service Bulletin
    TT – Twin Turbo
    UDP – Under Drive Pulley
    UP -- Up Pipe
    USDM -- United States Domestic Market
    VDC – Vehicle Dynamic Control
    VIN – Vehicle Identification Number
    VTD – Variable Torque Distibution
    WHP – Wheel HorsePower
    WOT – Wide Open Throttle
    WRC = World Rally Championship (competiton or WRC Spec cars)
    Impreza Bodies:
    GF = 5-door Impreza body
    GG = Impreza Wagon
    GM = 2-door (old gen) Impreza body
    GC = 4-door (old gen) Impreza body
    0 = 1.6L (not certain about this one)
    2 = 1.8L
    4 = 2.2L
    6 = 2.5L
    8 = 2.0L
    GD = New Gen Bodies
    BC = 1G legacy sedan
    BJ = 1G legacy wagon, straight roof
    BF = 1G legacy, raised roof
    GDA =New Age WRX Sedan
    GDB = New Age STi Sedan
    GF8 = Old School Impreza Wagon
    GGA = New Age WRX Wagon
    BD = '95-'99 legacy sedan
    BG = " " legacy wagon, raised roof, as in outbacks
    BK = regular roof legacy 95'-99
    __________________
  2. curly2k3
    nice list, sidenote:
    4EAT= Complete Pile of Crap
  3. scoobydreamin
    scoobydreamin Well-Known Member
    Looks like we have quite a few T & TLA's.
  4. Natural2JZ
    Natural2JZ Well-Known Member
    i know its a lil off topic but i was wondering, curly is ur svx auto still?
  5. SenorSubie
    SenorSubie Well-Known Member
    Not in my opinion
    And you base this upon?
  6. kickin_81
    kickin_81 Well-Known Member
    It took me a loooong time to remember these abbreviations in my head. I only wish it was available at the time I needed to know them a few years back when I was getting into my Subaru.
  7. Torc
    Torc New Member
    sorry its so late, but then again i'm in the same boat you were 2 years ago...torc=total noob....but learning :)
  8. LVT
    LVT Well-Known Member
    thanks!
  9. piddster
  10. wall of tvs
    I want a BJ!!!!!!!!!!1
    :p
  11. Torc
    Torc New Member
    thanks pidster added yours to the list
  12. mlgez
    mlgez Well-Known Member
    NOS I know is Nitrous Oxide Systems. Are all NO systems now known as NOS? Sounds like fallout from F and F.
  13. kongzilla
    kongzilla Well-Known Member
    this should be pinned.
  14. souy07
    souy07 Well-Known Member
    thanks.. i will try and memorize these.. ^_^
  15. Dynapar
    hey! 4eat can take more BHP then a 5mt.
    nice list. might wanna add some infr about the G / E engine codes. since those have been a hot topic. and maybe some thign about the 22B and how its the coolest car ever made (general subie knowledge).
  16. TSTRBOY2004
    VD?
    STD?
    F.A.G? (Fong's A Girl)
    all 3 of those ones can be used in the one sentence... :laugh:
  17. LVT
    add a 7 to the engine list, that's the usdm sti block. EJ257 = 2.5L semi-close turbo
  18. kickin_81
    ^^what are you talking about, Lue? It was in there! :p
    Nathan. Take it to the "official Fong and Nathan" thread. :roll: :laugh: IIRC, I was the winner last. Now stop making excuses and sell me your x-pipe. :hs:
  19. TSTRBOY2004
    you wish you could win... by my count more people got coke up there noses or spit out their drinks on a keyboard by my remarks then yours... ha ha ha
    about the x-over... we need to knwo for sure if it is the same as the 2.0...
  20. rskm1
    rskm1 Well-Known Member
    Good list!!
    Corrections:
    HT - Heel / Toe ("Heal" isn't part of your foot unless you injured it)
    Additions:
    NA = Normally(/Naturally) Aspirated (i.e. no turbo)
    PSI = Pounds per Square Inch (boost)
    and... what's that custom-tuning computer or boost-controller thingy I always hear about? I can't even remember the acronym right now, let alone the real name...
    And another important acronym to know:
    VTEC = marketing hype used as a subsitute for superior boxer design =)
  21. mndude
    mndude New Member
    DSM - Diamond Star Motor
    POS - Dodge Neon
  22. LVT
    wait, it's in there? i didnt see it before!
  23. Dynapar
    are you thinking the PP# = Perfect Power version # (ie 5, 6, or 7)
    the Cobb AP = Cobb Access Port
    TXS UTEC = Turbo XS someting or other. its a EM unit.
    TXS DTEC = Turbo XS DTEC (i dont know what that means, but it uses a gameboy)
  24. Chux
    no EA or ER motors? :(
  25. silver03
    I disagree. Why do you think this?
  26. piddster
    EJ22E = N/A 2.2L
    EJ22T = USDM 2.2L closed deck turbo
    EJ20g = 2.0L closed deck turbo sold over seas
    22B = I don't know with the closed deck phase 2 motor:dunno:
    IAC = idle air control valve
  27. Chux
    IIRC, the 22b uses a EJ22G motor, which appears to be the EJ22T with DOHC
    anyone know the codes for newer legacies? like my mom's '01 L sedan?
  28. Zola
    Zola Well-Known Member
    User Tuneable Engine Computer
  29. piddster
    The 22B motor is closed deck like the EJ22T, but it is a phase two design, meaning it uses an end-thrust bearing, as opposed to the center-thrust, and has the updated oiling system, since there are no oil squirters.
  30. esperunit
    esperunit Well-Known Member
    22B is not an engine code, its the actual name of the car. It's called a WRX/STi 22B. The actual engine code is EJ22G, which is only used in that one specific car. It is a bored out 2.2L EJ20G closed deck motor from the early WRX/Liberty RS with different heads.
  31. Ravyn
    Ravyn Well-Known Member
    Ahhh, okay, so my '00 2.5RS is infact a GC6 with the EJ25. I knew the engine model but the manufacturer code for my vehicle I was unsure on. Seems that everyone just wants to call them GC8's, even if they're the 2.5RS.
  32. curly2k3
    -having one in the SVX, not that bad, just weak...
    -Unfortunatly, yes :(
  33. Xcelor8
    Xcelor8 Well-Known Member
    Bump56
  34. vanddelor
    vanddelor Well-Known Member
    hey...what about WRX..???..what does that stand for..???
  35. TrisNiN
    TrisNiN Well-Known Member
    WRXs are GDB, or GD8 depending on the site or person. WRX stands for World Rally X(Cross), or World Rally X(Cross Country) on some of their early brochures that I have seen.
  36. 06WRXss
    06WRXss New Member
    So do the new WRXs have the same EJ255 motors like the Forester and Baja?
