Old Skool Legacy Parts For Sale
Discussion in 'For Sale : Car Parts' started by EtchyLives, May 12, 2008.
  1. EtchyLives
    EtchyLives Well-Known Member
    MNSubaru B-Series Member# 8=====D
    I finished tearing down and putting my car back together. I have some leftover parts available and there might just be some people who need them.
    Front control arms: These will fit any GC and will fit WRX wagons. WILL NOT work with WRX Sedan/STi. These can include the rear bushings if you need them. $50 for the set.
    Stock Front Endlinks: I have two sets. These will fit GD+ wagons and all GC Models. $10
    Stock Rear Endlinks: These will fit all GC models, all WRX Models through 05 (Possibly 06 and 07 but I'm not sure). They are the C-style links
    Brake master cylinder and prop valve: This is the piece that sticks out of your brake booster and holds the brake fluid. Should bolt up to any old school Legacy and most GCs. $10
    3.9 Final Drive Rear differential: This is an OPEN differential with a 3.9 final drive. I can't remember off-hand which exact models this will fit in but there are a number of older Imprezas that can use this. Buy it, crack it open, weld the diff, enjoy the fun. $50.
    Front brake calipers and brackets for a 94 T-Leg: I changed these out only because the available pads for this size are pretty limited. However, if you need some cheap replacement calipers for your GC-age Impreza these should bolt right up. They need banjo bolts, though. You can re-use your stockers on them. $50.
    All prices are OBO.
  2. Ej22TIM
    Ej22TIM Well-Known Member
    MNSubaru B-Series Member #713
    ill take the master cyl and prop valve.
  3. AWDimprezaL
    Monticello.
    your master cyl is BRAND NEW *******!
  4. EtchyLives
    OK...
  5. Ej22TIM
    oh ****, you have abs dont you. either way, I need that trailer hitch
