Can I run Open ECU on a 16g Turbo? or I'll have to go with the VF39 if I want to run Open ECU? What kinda Turbos can I run with Open ECU?
Ummm.... just about any turbo you want. it's just a method of tuning the stock ECU. What you need is someone to tune the ECU to your setup...
u can spend more for a 16g or just stick with a vf39 and go with that, since it's cheaper...or you can go with a vf39 and upgrade to a 16g later if more power is needed
