open ecu tuning
Discussion in 'Modifications And Maintenance' started by Kevin, Feb 13, 2008.
  1. Kevin
    Kevin Well-Known Member
    Andover, Minnesota, United States
    what kind of software do most of you use? is there one that has seen more succes than the others?
  2. zyklon
    zyklon Well-Known Member
    Eagan
  3. carl
    we gotta gooooo
    search button is your friend
  4. Kevin
  5. TSTRBOY2004
    search button is your MAGIC spell casting friend... wHich will answer all your questions ;)
  6. Vector
    Vector Rally Organizer
    Enginuity/RomRaider and ECUFlash are pretty much what you want to use.
  7. Kevin
    thanks... mark?
    this is kevin.
  8. Vector
    Yes, this is Mark.
    You might want to keep in mind that since Tom (Wall o' TVs) used to own this car, unless it's been monkeyed with since, probably has a damn good tune job right now, and you probably don't want to muck with it until you start switching out stuff.
    We should talk again about the exhaust & other stuff.
  9. wall of tvs
    dream ftw
    The car is in a completely different configuration from when I owned it. The only part that got transfered over was the inlet pipe.
    w_o_t_boy retuned the car after it went back to stage 2.
  10. Kevin
    the one thing i want to tune for right now is the atmospheric BOV. it has a stutter at intial startup.
  11. tangledupinblu
    MNBugeyeMafia#001
    Don't think that's possible?
  12. Kevin
    i am pretty sure it is,
    when the BOV is atmospheric and not recirculated into the intake, your maf is not seeing as much air so it is studdering. im pretty sure thats why. thats what i was told anyway.
  13. tangledupinblu
    MNBugeyeMafia#001
    Huh, I have a HKS fully atmospheric on my 02 with a stage 2 set-up. When I got the BOV I was told that there was no 'tuning' it.
  14. Vector
    While I'm sure it's possible to tune for it with the right management, my understanding is that the stock ECU (and hence any tuning that uses it) doesn't have the capabilities needed. I could well be wrong though.
  15. Bullwinkle
    Saint Paul
    This is correct, there is not with the stock EM.
  16. Ronnie@RSmotors
    What brand BOV? What you should do is get a stiffer spring if its staying open at idle or adjust it tighter.
