What are some other turbos to look at besides the super 16g. I want around 300whp. I am planning on getting the super 16g as long as deadbolt gets one in time. If not I will have to buy something else...
I dont see a super16 getting you 300whp; not on a Mustang atleast. Ide go 18G but ive told you that 20349583049854 times already.
http://www.ultimate-racing.com/Products2/WRX/WRX_T3T04E_TurboKit.shtml If you want 300WHP this is a good turbo kit to get...Full boost @ 3800-4000 Slight Lag but kicks hard, on Stock WRX Block. Capable of 500WHP, on DD maybe 400+WHP (upgraded Block and Fuel required) Full Boost between @ 3300-3500 depending on Block upgrade 2.2+ My VF34 hits Full Boost @ 3500-3700RPM Stock WRX Block 260WHP (mustang) Needs to get retuned...Hopefully after the tune I should be @ 270-275WHP and Full Boost around 3300-3400RPM @ 18.5psi. Hope this helps...
Yeah so i talked to Jorge and now i have no idea what i am getting. He says go for a td06 20g like erik had but i want my motor to last. I hate picking out a turbo...
Well i think i am going to go for the SBR TD06H 20G...if someone cares to talk me out of it that would be ok... lol
Q: Have you ever felt 300whp? If not highly suggest it. Soon before you know it you will be hungary for more. The truth is its really not that much, depending where your coming from.
quit being a little bitch and buy a turbo why not go green? hahaha. you're engine will last as good as your tune is, if you just want 300whp, you can stop there with the 20g and have room for more once you upgrade the motor, or try and go for max, which I am guessing will be around 330whp on your motor on pump most likely. Ben
