PART OUT: 1996 subaru impreza with turbo kit and EJ255 longblock
Discussion in 'For Sale : Car Parts' started by modsuby, Dec 12, 2010.
  1. modsuby
    modsuby New Member
    Well after a year and a half of boost my little 1.8 finally went out with a BOOM! There is a hole in the top of the block about 6 inches round. Im done with the car and need it out of the driveway. It is a 1996 impreza 2dr green i.8l 5-speed 210,000 miles, it has some rust, dents scratches and cracked parts, nothing near perfect. I just broke a shift rod while i was changing a part of the shift linkage and had the tranny apart to replace it. Everything looks great and shifts good when running half syncromesh in the tranny. THere is a turbo kit that i built on there running a modified td-04 (off a 03 wrx). I was running 21lbs of boost for 6 months with no problems. There is a small exhaust leak in the header that can easily be welded up.
    I would like to sell the turbo kit complete since its all designed to be together. If you are not mechanically inclined do not purchase! I had it working for quite awhile and worked out pretty much all the bugs but it still isnt perfect. You will have to know what you are doing to trouble shoot and tune. I AM NOT RESPONSIBLE FOR ANY DAMAGE THAT YOUR CAR MAY SUSTAIN BY BOOSTING IT,
    All of it is still in the car, so i will help take it off when you give me cash.
    ALL PRICED ARE OBO:
    Turbo kit: $500 obo WITHOUT ELECTRONICS
    -Modified Td-04 turbo (welded wastegate and rotated compressor housing)
    -custom UEL header (can use n/a or with this kit)
    -custom up-pipe, downpipe and 38mm EWG-
    -(EWG has 7psi spring)
    -custom 3" exhaust
    -Forced air tech top-mount intercooler- $75
    -Ebay BOV
    -manual boost controller
    -Custom intake
    -PCV system (2 catch cans and hoses)
    -coolant hoses (for turbo)
    1994 turbo legacy 2.2l heads with Delta 220 grind cams- $150
    Delta 220 grind turbo legacy cams- $100
    Sti yellow side-feed 550cc injectors-$100
    turboxs knock light (no sensor)-$100
    Greddy Emanage blue with all harnesses and Map sensor, serial cable for laptop- $300
    Auto meter vacuum/20psi boost gauge-$20
    AEM EUGO wideband without gauge (someone stole the gauge)-$100
    More items on car:
    3 month old starter-$30
    front axle (used for 2 days)-$30
    5 speed tranny (210,000mi)- $150
    radiator (10,000mi)- $70
    1.8 intake manifold with sensors and harness-$50
    Complete A/C system (no evaporator)- $100
    15" alloy wheels with worn tires-$75
    All of this car is for sale so if you want something that i didnt list ask and i will probably have it.
    not on car:
    14" steel wheels with worn tires- $15
    Rear disc conversion: $200
    -rear knuckles
    -calipers/brackets
    -NEW oem pads
    -all seals NEW
    -NEW lateral arm bolts
    -NEW lateral arm bushings
    -rotors
    -e-brake stuff (no cables)
    2 p/s pumps different styles-$10 ea
    A/C compressor-$10
    pair of headlights-$25
    sohc timing covers-$15
    I have a 2009 WRX longblock EJ255 300mi-
    - complete with everything under the timing covers including gears, idlers, pumps, belts and all sensors that come on heads. The block had rod knock and was warranty replaced at 300 miles. I picked it up from subaru, sent the crank to crankshaft supply and they polished it up and gave me new ACL bearings. The block is put back together with new bearings and the pistons are not installed yet (was going to put in a set of forged pistons). I have everything that came with the motor and tons of new gaskets including new headgaskets. I am willing to sell the heads and block separate or together. The heads are not on the block yet but everything is there.
    EJ255 heads- $1500
    EJ255 shortblock- $2000
    Complete EJ255- $3200
    If you have any questions ASK lol. The best way to get a hold of me is to call me at 763-443-9621 or email me at [email protected]
    THANKS FOR LOOKING!!!
  2. asiandude
    asiandude Well-Known Member
    How much for the shell with no motor and tranny
  3. modsuby
    modsuby New Member
    Well i cant seem to figure out how to edit my post so ill post some pics and prices here.
    Car as is with engine and tranny: $800 obo
    Car with turbo kit as it sits now: $1500 obo
    turbo kit with electronics: $1000
    I need this car out of the driveway. I dont have a way to take out the engine or tranny because my garage is at the top of a hill and the car is at the bottom. I dont feel like doing it i the snow or cold for that matter.
  4. demong
    demong Well-Known Member
    lol, nhia -asiandude- , this will definitely be a good project car.
    I may be interested in the hood, starter, front axle, and front calipers.
    hows the clutch on the 5 speed tranny?
  5. KRYPTO
    KRYPTO New Member
    Greddy Emanage blue with all harnesses and Map sensor.
    Will this work on my 98 Legacy?
  6. modsuby
    modsuby New Member
    The clutch is a stage 1 f1 racing clutch, it was starting to slip a little at high boost when its cold out.
    The Emanage is a piggyback that can be wired into pretty much any car. It will work but its kind of useless unless you have boost.
  7. Saabaru
    Saabaru Well-Known Member
    I've been out of the loop a while... Would the exhaust parts, Up-dp-"custom exhaust" fit and work well on a wrx? I know subies are like Legos, but don't remember if this would all mount right up. Thanks!
  8. RS MN
    RS MN Well-Known Member
    interested in this stuff for my leggy.
    does the downpipe hook up to a wrx/sti exhaust? or would i need to make a custom one.
  9. silver03
    Overall condition of the wheels? subie factory wheels? thanks rick
  10. KRYPTO
    KRYPTO New Member
    Will the hood fit a 98 Legacy?
  11. RS MN
    bump.
    pleaseeeee...
  12. niterydr
    niterydr Member
    You've got PM, lets talk.
  13. vega
    vega Active Member
    He sold the car already you guy an delet this thread
  14. badbennyb
    Can the seller confirm this?
  15. modsuby
    modsuby New Member
    Sorry everyone for not replying as life has been hectic, the car is sold but the EJ255 is still for sale. You can delete this thread.
