I bought a 04 STi for the drivetrain so here are the unneeded items The engine, gearbox, DCCD, wire harness, ecu, water sprayer, wheels, and seats are going to be kept. The rest is up for grabs. 40k miles on the clock Interior Spedo cluster $350 Steering wheel Air bag blown $100 Wiper arm stock $40 head light stock $40 "A-B-C" Pillers $25 each cheaper if you buy multiple Front Door cards $150 Right Rear Door card $75 Upper Dash $50 Center shifter Trim with the STi trim $50 Clock $25 Make an offer on any other interior part Drivetrain Rear diff, axles, subframe, driveshaft, hubs, Brembo calipers, and rotors $1750 Front Brembos with Rotors $800 Brake booster and Master Cylinder $200 ABS Assy. $200 Invidia V2 Downpipe $200 Exterior Right Rear Door a fair bit of scratches, $150 Side skirts, few scratches on the left side B.O.
dibs on clock! would the side skirt be the same as the one on my 02 wrx? if so i will take that also...
Mlgez- it is a un-catted DP angusracer- I responded to your PM Speedemon- the seats are being kept, but all other parts are avaiable Dream- I got a PM from Pete Brian Shorten- it WAS a standard mirror but thats lost Yea the old owner is a good friend of mine, its a bummer that he did this.
^ FMIC is toast. DP has been called dibs on. also if your looking to turbo your car the VF39 (stock STi turbo?) might be alittle too mig for ya. i am not exactly sure, but its worth looking into.
i think the vf39 would be a good turbo. the key is to get as much power as possible with the least amount of boost. with a bigger turbo, it'll create more power at say 8psi compared to a smaller turbo. with the higher compression of the n/a....no lag...=D
is the OE STi axleback available? (sorry, whats the diameter on an STi axleback anyway? 3" 2.5"? and would it bolt up to a WRX resonator pipe? total STi n00b here :ugh
the Turbo, up-pipe are being kept I will be using all the pedals It had a dc sports catback... which is now destroyed the spare tire is going to be kept the axles are also going to be kept
Mike do you have the ECU out of that? Stock unit? I don't want it but i would like to take some pictures and look at the chips. Do you mind? I will be bringing my car to you guys Tuesday so I could look at it then.
