-Tail light, has a small crack, and also has a small piece of black plastic that is missing on the bottom..you will see the damage in the 2nd pic - $25/obo -carpet, decent shape. could use a washing, and the is a bit of damage where the dead pedal is - $50/obo -Pedal (clutch, brake, and gas) - $30/obo -4 PSM doors w/ door cards and glass and speakers - selling whole for now - the RR door window has a bit of damage on it, I have other pieces of glass for that. the RF door is a bit damaged by the side mirror. - price negotiable depending on which door you want ...but around $100 each -Blower unit - $40/obo -Front and rear seat...good condition... left side cushion of the driver seat a bit worn cause of my heavy ass getting in and out -$300/obo -Wiper arms with rain X wipers on them - $40/obo -Wing break light - $20 -Fog lamp - $25 -PSM trunk lid...some damage on the driver side of it.....make me an offer -Ebay DP, not sure if the flex is still good or not - $25/obo -Stock rear sway bar - $25/obo -Stock TMIC w/stock Y-pipe (needs to be cleaned) - $40/obo
- Cluster (light for the CC is out) says 192k IIRC - $40/obo -Stock fuel pump - $50/obo -Fuel level sending unit I believe that's what it is - $25/obo -Clutch Cylinder and actuator + lines - $50/obo -Dome light w/ LED panel from DDM Tuning in it - $15 -Map lights - $10 -Blacked out Ebay headlight (has broken piece) - $20 -Washer fluid reservoir - $20/obo -Coolant overflow - $20/obo -Steering rack - $40/obo -2 radiator fans 1 just blades other whole - fan only - $10 full fan - $20 -Drive shaft for a manual trans - $100/obo
ill take blower unit and all of the things under the passenger and driver side that divides the air or a/c / heat
I'll look to make sure, it was in good shape when I looked at it. It was probably the best door out of the 4. Did you want the whole thing? door, glass, speaker, door card, side mirror. and if you get the rear as well you could have a full Grimmspeed decal
Scoob - yes and yes. Xodad - yes and yes, Also do you still need one of the door molding. ....I haven't forgot. .. lol
Parting out under the dash stuff? If so, I may be interested in the body integrated unit module deally bob. Apparently my one LED footwell light was too much for mine. Thanks.
Interested in some things if you have them in decent shape: fog lights, side skirts, short block (or maybe long block), turbo, turbo inlet tube. PM me if you have any of this stuff please and thank you.
Damn, that first pic is a bit too much to look at. I paused for a moment... Glws all of the still good parts!
......................MORE PARTS ......................... Stock intake manifold - $70/obo Stock TGV's - $75/obo Stock injectors - $100/obo ....................ALL 3 $200................. Stock turbo inlet - $25 Stock long block - $400/obo Alternator - $45 Perrin crank pulley - $50/obo
also there may be some bent valves on the heads, since I knocked both Pass. side cam gears during the accident.
FEW MORE ITEMS Stock Td04 - I think 170k ran good when installed it on my car in like Jan. - $75 Up pipe - $20 Front calipers/w pads and brackets - $50 Rear calipers /w pads and brackets - $40 ABS sensors - $20/ea Rear diff (there is a corner of the rear cover that is chipped off, didn't seem like it was leaking - $100
