Parts, parts, parts...tons of parts
Discussion in 'For Sale : Car Parts' started by Pearsonface, Nov 10, 2015.
  1. Pearsonface
    Pearsonface Well-Known Member
    Updated list of parts that I want to get out of my garage. Mix of both new and used.
    (Pictures will be up later tonight.)
    Blouch 18g Turbo
    LOVE this turbo. Decided to go with a smaller turbo on my 2.0 since it's my daily. Journal bearing and minimal shaft play. No leaks, noises, cracks.
    $500
    eBay Huge TMIC with Grimmspeed y-pipe kit
    eBay TMIC's are always hit or miss. I got lucky with this one minimal pressure drop and was always cold to the touch after driving. Switched to a V8 JDM STI tmic because this on sat too close to the turbo. (Blouch 18g)
    6k miles
    $75
    FMS FMIC kit
    Missing 1 coupler and 1 pipe. Have no idea what pipe is missing but everything is brand new including core. Went with V8 JDM STI top mount instead of going front mount.
    $80
    Prosport Boost Gauge Blue/White (Mechanical)
    Got Defi's so this have been packed up for a while.
    $20
    Vf39 IWG
    Went EWG so no use for this anymore.
    72k miles
    $15
    Denso MAF Sensor
    Was troubleshooting a lean issue and got this to attempt a fix. Found out my stocker is functioning fine.
    10k miles
    $50
    Mishimoto Racing Thermostat
    Bought and then decided to just replace with OEM.
    NEW
    $20
    Sti Sidefeed Injector O-Rings
    New from dealership
    $10
    Rear Engine Re-seal Kit
    New from Flatirons Tuning
    806786040 - Rear Main Seal
    11831AA210 - Rear Access Panel
    800406140 (x5) - Access Panel Screws
    800406150 - Access Panel Locking Screw
    806931070 - Driver's Side O-Ring
    $40
    Parts from 2004 WRX Java Black-
    Exhaust Manifold
    All heat shields removed. New crosspipe gaskets installed.
    $30
    Stock Flywheel
    Needs to be resurfaced but in great shape. Went with lightweight comp flywheel when upgrading the clutch.
    $50
    Bypass Valve
    Stock BPV that has been crushed to hold more boost. Held 22psi to redline no problem with a vf39.
    90k miles
    $15
    Stock Airbox
    Includes flexpipe and newish K&N filter. Great shape.
    $40
    Spoiler
    Lovely whale tail spoiler in Java Black Pearl.
    $50
    Stock Steering Wheel
    Has some wear but is in good shape. No tears. No cruise control.
    $20
    Head unit
    6 disc changer works great. Swapped for black unit from bugeye
    $20
    Radio bezel
    Have 2 of them-
    1 pasti-dipped black (flawless)
    1 black wrinkle coated
    Wheels with NEW Potenzas
    Painted black. Potenzas have 5,000 miles on them. From 2004 rex. Would make a great winter setup.
    $450
    Pm or call/text Matt @ 651-303-8047
    Located in Afton, MN but work in Oakdale/ Saint Paul area.
  2. SlowSC
    SlowSC Well-Known Member
    FMS FMIC kit for $80?! is that a typo?
    Ntxhuav_Khang likes this.
  3. Deathly
    Deathly Well-Known Member
    I believe he means the piping.
  4. tangledupinblu
    He said that everything is new including the core...sounds like the "nearly" complete setup
    SlowSC likes this.
  5. Deathly
    I read all that, guess I just spaced on what I had read when I typed that :p
  6. Pearsonface
    Not a typo. It's a FMS ebay kit that includes: core, couplers (blue) and piping. Missing one pipe that was sacrificed for a friends setup. All new never used. Will take some pics on my break around noon.
  7. Pearsonface
    More parts -
    Kinugawa Forged IWG
    Used for 2-3k miles when my blouch iwg went out. Since then have swapped to an EWG setup so off to a better home it goes!
    $80
    Stock WRX Scoop
    Java Black from 04
    $30
    Kartboy Exhaust Hangers Extra Long (15mm)
    02-07 Applications
    Have 8 of them brand new.
    $6 a piece
  8. TMF
    Pics of wheels? Willing to split?
  9. Pearsonface
    I would prefer to not split them up as I would probably just use them as an extra winter set if nobody wanted them. Heres a picture of them on the car I will haul them out of the garage and take pictures this evening. IMG_1717.jpg
  10. SlowSC
    What model application is the kit for? Definitely interested in seeing those pics.
  11. Pearsonface
    FMIC is for 02-07 wrx
  12. Pearsonface
    Pics of FMIC will be up in a little over an hour
  13. DoughtCom
    DoughtCom Well-Known Member
    I'll buy the FMIC, I'm building a super secret sleeper. The core looks a little smaller.
    I'll also take the injector 0-rings.
    I'll Take 2 kartboy hangers too.
    America.
  14. Deathly
    Both radio bezels?
  15. Pearsonface
    Bezels are $10 a piece
  16. phi11
    Yup, I'll buy the steering wheel, please.
  17. Pearsonface
    Steering wheel - Pending
    FMIC - Pending
    Sidefeed O-rings - Pending
    BPV - Pending
  18. belalegosi
    belalegosi Well-Known Member
    Pics and mileage on the Blouch Turbo?
  19. SlowSC
    What's the condition of the boost gauge? Do you have a pic?
  20. Pearsonface
    FMIC - SOLD
    Side Feed o-rings -SOLD
    BPV - SOLD
    Steering Wheel - SOLD
    Radio Bezels - SOLD
    Everything else is still up for grabs.
    phi11 likes this.
  21. Jake underwood
    Jake underwood Member
    Is the spoiler an STi spoiler or just the wrx one?
  22. Deathly
    Whale Tail=WRX
  23. tangledupinblu
    "Whale tail" is the WRX one.
    Jake underwood and Deathly like this.
  24. Jake underwood
    Dang it, thanks guys.
  25. Chee Yang
    Chee Yang Member
    Any pictures of the Ebay TMIC? as well as the Blouch 18g turbo as well?
