These are just things I have collected over the years and simply need to get rid of them. If you have any questions, best way to contact me is TXT 6513682491 Reffer to link (underneath) for comparability $60 http://www.amazon.com/Centric-136-47003-Clutch-Master-Cylinder/dp/compatibility-chart/B000C06FRK HKS down pipe $80 obo 02 wrx top mount (clean one with green tape only sorry only picture I have) $30 02+up RS/L/OUTBACK/03 WRX calipers with hardware $80obo Wrx Catback $80 obo 02 Wrx brake set up pads/rotors/brackets/calipers $200 obo 02 Wrx brake set up pads/rotors/brackets/calipers $220 obo
yes they're direct bolt on. But you have the same calipers. If you want bigger brake set up just get wrx mounting bracket and rotors and your set. unless you want to buy my setup, everything brand spankin new!
The white calipers (powder coat or paint?)...willing to separate caliper/hardware from the others? Also are those rear calipers or front? Otherwise I am in need of rear pads/rotors and front calipers/hardware.
These are front ones. They're just rattle canned high temp painted for the heck of it. I preffer to sell everything together sorry. I don't want to be left with leftovers. Hope you understand.
The first ones you have listed are just the front calipers and hardware. Do you have a part # to check applications? If it will fit the 02 WRX then i'm interested.
They're both rebuilt 2002 wrx calipers/mounting brackets/pads/rotors. The boxes are just boxes to keep them in so no part numbers sorry. But I assure you they will fit as long as your brake set up is 2002. 2003 are different. I also have 2003 calipers with hardware kit. I had plans on swapping them into GF's but things didn't work out.
I was asking if the downpipe was JDM length or not. USDM turbo downpipes are different. I was not talking about single/twin scroll differences.
I very likely need front brakes for 99 Impreza. Will need calipers and everything. What do you have left? And would I need any other parts to complete the swap? Thanks!
