pcv valve
Discussion in 'Modifications And Maintenance' started by ruberdukwrx, Jan 28, 2008.
  1. ruberdukwrx
    ruberdukwrx Well-Known Member
    Should I cap my pcv valve off if I am venting my crank case to the atmosphere or keep it hooked up as normal?
  2. gran0393
    gran0393 Well-Known Member
    heep it hooked up as normal, i don't think it'll run too well with it venting to the atmosphere plus if you get water in the crankcase that can't be too healthy
  3. DISCOPOPE
    DISCOPOPE Well-Known Member
    mine is capped at the throttlebody.
    i run vta.
  4. piddster
    VTA?
    I've seen the "self-oiling, lol" breather filters on the rocker(cam) covers run fine with the main PCV port going to the PCV valve. I've thought about doing that to clean up the mess in my engine bay.
