Perfect Power SMT6/7
Discussion in 'Modifications And Maintenance' started by Dynapar, Sep 13, 2005.
  1. Dynapar
    Has anyone seen, or used the SMT6? is it eas to use? does it work well? what do you think?
    What about the SMT7? is this only for wrx/sti/lgts?
  2. AWDimprezaL
    i'll be using the 6 for my setup, its around 450 doll hairs, tunable with a laptop
  3. Dynapar
    have you seen the interface before? or know anything bout how hard it is to install?
  4. AWDimprezaL
    it would be like installing a s-afc, but perfect power will find you the correct diagram for your car, i think its 6 wires
  5. Dynapar
    then it connects via serial to a laptop, or desktop hehehehehe
    any idea what the laptop tuning software is like?
  6. AWDimprezaL
    not a clue, but i think you can download different setups and stuff right from perfect power
  7. Dynapar
    when do you think your going to get one?
  8. AWDimprezaL
    not untill after my funeral...err wedding
  9. Dynapar
    lol, any idea when that will be?
  10. Zola
    Zola Well-Known Member
    I've seen the tuning software. It's GUI based, reminded me of DSMLink a bit. Seems like a waste of money if you aren't turbo. User base practically non-existent on this continent.
    Yes it's cheap but it's still a piggyback. Why bother when you look at what's going on with the AccessPort/StreetTuner/ProTuner.
  11. AWDimprezaL
    because i am going turbo, and swapping a complete wrx wiring harness would be insanly idiotic, all just to use an accessport, for my closed deck ej22T, running 10-15 psi MAYBE
  12. Dynapar
    exactly! i tried to read up on this thing on other boards and it seems like no one has one. altough in my searchings i did find a download of the tuning software, and have taken a quick peek at it. and well...... it means nothign to me since i know jack about tuning software.
    i wonder if it would be good enough to squeeze some extra juice out of a NA motor. or if it would be more worth it to get a hydra (which seems to have a little large use base, but still almost un heard of)
  13. OchMan20
    OchMan20 New Member
    I am actually going to buy this thing within a couple of weeks. I was told to email sean at rallitek and he can answer all of your questions. nasioc has a lot of good info about it too. I am excited to play around with it!! :D I have heard that stock rs's get about 10 hp/10tq. More can be had if your car is modded.
  14. OchMan20
    OchMan20 New Member
  15. Dynapar
    thats informative
