Pit Bikes
Discussion in 'Off-Topic' started by Fleck, Feb 15, 2008.
  1. Fleck
    Fleck New Member
    Looking to get one, but i dont have any experience with them. Does anybody have one and what kind. Whats a good bike for around $1,000. I dont need a dirt bike i just want a pit bike to mess around with during the week and us it to get back in forth in the pits at the races.
  2. Ej22TIM
    Ej22TIM Well-Known Member
    xr50 with 88cc big bore kit! my friend has one and its f-ing fast!
  3. dipp
    dipp Well-Known Member
  4. ruberdukwrx
    ruberdukwrx Well-Known Member
    sell ya a cr250 for $1800!
  5. flstffxe
    flstffxe Well-Known Member
    Kawasaki KLX-110 is just a bit bigger over all then the Honda XR-50. The KLX-110 is a rebadged Suzuki DR-Z110. Used they can often be had for around $1000-1800. The XR-50 with a big bore kit or stroker kit will walk on a 110 on an indoor track because you can just sit in 2nd gear and run the rpm band. the 110s you are always down shifting in turns. outdoors or back yard goofing around, 110s and up all the way. Thumstar have an ok reliability but come with many goodies one will likely spend money on any way. Used they can also be found in the $1k-1800 range depending on how old they are.
  6. Gridlocked
    A couple of years ago, I built a 1970's Honda CT70 and threw in a Lifan 110cc engine, totally rebuilt everything including a crotch rocket style exhaust. It was a lof of fun.
    I've got better pix, but this is all I have now.
  7. SomethingsWrong
    you could always build a mini chopper or barstool.... :)
  8. Fleck
    Fleck New Member
    Cool, thanks for all the info guys. I will keep in mind about the 110's on an indoor track, cause i may race it indoors, but who knows. I am still researching what would be perfect for me, cause there are some bikes out there that are just junk, and you can tell just by the craftsmanship.
  9. Wakaba
    Wakaba BANNED
    '02 XR50 frame
    Zonger 125cc
    Yoshimura/Mikuni flat side carb
    Takegawa Mg stator cover
    Takegawa manual clutch (stock honda spring clutch seen)
    16/32 gearing
    bottom exit CF can
    Down Components +2" swinger
    DID Gold 420 chain
    Generic Chain Guide
    Generic Chain Roller
    NSR-50R fork with HRC preload adjusters
    I'Shock
    Kitaco upper tripple
    Aluminum rear set
    D2 +4" side stand
    G-craft headlight brackets
    gutted and rewired Baja Designs street legal kit
    Black plastics w/BBR "Bomber" graffics
    BBR tall seat
    Daytona NSR rotor adaptor
    Daytona 8 hole alum rims, 10x2 front 10x3 rear
    Too fast, and too dumb to play on the streets anymore. Getting a BBR SP-5 fork, and some dirt wheels/tires again. Should be a fun runabout when I get back.
  10. flstffxe
