Place your bets! Which state is my transmission going to pop
Discussion in 'General Subaru Discussion' started by Beej, Aug 13, 2005.
  1. Beej
    Beej New Member
    OK, I am going to do a 28 hours stint back to MN from Los Angeles in 2 weeks.
    I am running a EJ205 on my STOCK RS TRANSMISSION! It was this combination that was said to have downed the hindenberg and assassinated kennedy.
    Now it's time for YOU, the wonderful people of MN subaru to place a bet on which state my transmission is going to grenade itself.
    Payout will occur @ firestone late august/early september.
    PLACE YOUR BETS!
  2. LVT
    LVT Well-Known Member
    The RS tranny holds better than the WRX...so i say it won't break.
  3. Beej
    Beej New Member
    You will put put some money on that??!
  4. Justin
    Justin Well-Known Member
    almost nothing can be worse than an 02-03 rex tranny.
  5. Dynapar
    from what i have heard the RS tranny is almost if not the exact same as the WRX tranny. so w/ a stock wrx engine you should make it.
  6. tbone
    tbone Well-Known Member
    maybe wagonl still has that type RA tranny for trade
  7. kickin_81
    kickin_81 Well-Known Member
    The final drive is shorter on the RS tranny. It'll hold up; it did with mine when I made my journey from Fresno, CA to MN. :D
  8. Dream
    Depends on how you drive.
  9. readymix
    I voted Nebraska
  10. Back Road Runner
    All the way baby!
    ...unless you're a nut behind the wheel, then...not out of the parking lot. :mrgreen:
  11. LVT
    i know you're gonna cheat and break the tranny :p ...
  12. Beej
    Beej New Member
    So much confidence on the RS tranny. I like it.... :)
  13. FuJi K
    The gearing on the RS is shorter than the WRX, and ALSO the final drive helps relief some stress. The strength of BOTH trannys are not much different. the '03 WRX tranny's 1-2nd gear were widen to Type RA width, as well as the Foresters (lucky you Fong).
    Drive it well and you won't break it. I put 400whp in 1st gear!
