plug it
Discussion in 'Modifications And Maintenance' started by tangledupinblu, Nov 3, 2006.
  1. tangledupinblu
    Need some info/opinions on best plug and wire set up for 02 wrx. Been feeling somewhat sluggish lately. and i'm at 111,128 miles, probably hasn't seen new plugs since it left the dealership!! Let me know:biggthumpup:
  2. LilRed
    LilRed Well-Known Member
    NGK is the way to go!
  3. mlgez
    mlgez Well-Known Member
    It has plug wires??? OK. It doesn't have the coils right on the plugs? I was sure they did.
  4. Squiggly
    Squiggly Squiggly
    copper plugs run better but dont last as long
  5. Dynapar
    you should have idividual coil packs, thus no plug wires.
    stock plugs run the best unless you start getting crazy
  6. tangledupinblu
    I'm just in desperate need of a tune-up and i've never worked on this engine before. But the warranty is up and i'm ready to start on getting the hands dirty. small stuff first, steak later! No plug wires, good to know! How long do the copper plugs last? Is it worth the money to get stock plugs and let the subie dealer install?
  7. Xcelor8
    Xcelor8 Well-Known Member
    You can get a 20% discount to take it to any morries Suby, there is also quite a few guys on here that do great work, with reasonable prices, cheaper than the dealership.
  8. 02blubru
    Go with stock plugs from mtka morries and you do not need wires as the coil packs are right on the plugs. 40 buck for 4 plugs and you are set, just make sure you get 4 of the same. (that happened to me got 3 right ones and one wrong 1)
  9. tangledupinblu
    Brooklyn Park suby right up the road. 20% off sounds good, but hooking someone else up with some loot sounds good too if anyone is interested in an assist tune-up. would be nice to see the work being done so i can learn more about doing the stuff myself, can't do that at the suby dealer!
  10. Xcelor8
    Gotta mention your from the mnsubaru forum to get the discount.
  11. tangledupinblu
    Sounds great, thanks for the heads up!
