pm storage??
Discussion in 'MNSubaru Front Office' started by TSTRBOY2004, Aug 1, 2006.
  1. TSTRBOY2004
    I noticed you can make your own folders but you cant move anything to them.. ie it allows you to delete or mark as read or unread?!?!?!
  2. Justin
    Justin Well-Known Member
    that would be nice. right now i have one folder with 848 pm's in it....which is a complete mess
  3. Steve-o
    check the boxes of messages you want to move, drop down at the bottom "move to folder...", follow directions.
  4. TSTRBOY2004
    hmmmm seems like when I posted maybe I didnt say clearly enough that there is ONLY A DELETE or MARK READ / UNREAD and the mark as xml/csv/ text.... option that appears... maybe the "instructions" are in US english that is so backwards that I cant read it?!?!?! or maybe there is NO instructions just a drop down box with 5 options that have nothing to do with listing any folders you make of your own...
    And seeing as Justin who knows the workings of the site / how it works says he has the same issue then maybe I am not misreading something....
  5. subaru4
    subaru4 New Member
    I am only able to choose from delete, mark as read, mark as unread, download as XML, download as CSV, download as TEXT.
  6. Steve-o
    There is a "Move to folder option...". It is the very first option. I attached a screenshot below. I tried 3 different accounts varying in user level and they all have it. For the record "follow directions" was part of the process after you choose move to folder it gives you directions on how to finish the move....
    :hsugh:
  7. subaru4
    subaru4 New Member
    Ok i get it now.
    1. click user options
    2. click on edit folders under private messages on the left
    3. name the folers whatever you want to, then when you are done naming the folders click save
    4. click on private messages where you can put the check mark next to them
    5. go down to the selected messages click the go button next to the move to folder.
    6. then choose what folder you want the messages to be in
  8. Justin
    i dont know anything about this site.
  9. TSTRBOY2004
    I meant forum inner workings a bit more than I do...
  10. TSTRBOY2004
    gotcha now... thanks.. didnt realise that was also an option..... thanks again
