post deleting
Discussion in 'MNSubaru Front Office' started by 02blubru, Jul 27, 2008.
  1. 02blubru
    I can not seem to delete my posts anymore.
    did the process for doing this change??
  2. Paul Revere
  3. readymix
    The process has always been that you can't delete a post after you have made another post. So if you go and post something, then post again, you can't delete it.
  4. 02blubru
    I can not even delete a post if I don't post after it. Even if nobody has posted after it.
  5. 02blubru
    I just tried on the above, and no luck. I do not get the delete option I used too
  6. Paul Revere
    It also doesn't show me if I have edited my post.
    *does this work?*
  7. Aegis
    yeah, you used to be able to just "delete posts" a while ago, it changed with the upgrade i think. :\
  8. 02blubru
    it never shows you that you edited yours... you know you edited.
    so is there no way to delete them???
  9. TSTRBOY2004
    it does show that you edit your own... only if after 1 min I believe... well it used too
    Bill rocks my world
  10. TSTRBOY2004
    see above post!!!
    maybe you have to add a reason in the reason for editing???????
  11. TSTRBOY2004
    yep... I just added text then posted.. no editing.. then re-edited with a ... in the reason and it showed
  12. 02blubru
    good work nate.
    testing
  13. Hallywood
    Hallywood Well-Known Member
    Mods: Can't you click the box that allows people to delete their post?
  14. WRX1
    Well, I haven't changed anything on the site that has to do with deleting posts. I will dig into it the next day or two.
  15. prezawagon
    prezawagon Well-Known Member
    The mods don't have admin level access. We'll check with the admins and see what changed. I'm guessing that an option got reset from an upgrade.
    edit, yeah, what Russ said.
  16. WRX1
    I looked and it is turned on. :dunno: You should be able to delete your own posts, but not threads.
  17. 02blubru
    testing
    my delete button is back.
    orrrrr
    I was just a moron and was over looking it.
  18. 02blubru
    my delete button is gone again...
  19. TSTRBOY2004
    are you mad??? LOL
  20. WRX1
    Well, I can tell you that it isn't anything that I have done (site upgrades/changes). I haven't been around for the past 3-4 days.
  21. TSTRBOY2004
    are you on your slackbury???? or normal laptop??
  22. 02blubru
    laptop
  23. TSTRBOY2004
    weird...
    yep.. NO DELETE button for me either... so Bill isnt just mad.. although that is true
  24. Aegis
    Nothing has changed. You are only able to delete your most recent post. If you post one thng in one thread, and then another in a different thread, you will not be able to delete the post you made in the first thread.
  25. TSTRBOY2004
    yes.. but I tried it with that last post... it has no delete button.
    just tried it on this one.. the last post I made then went straight into edit mode...
    oh well I dont care.. I dont delete my posts.. DONT HAVE too... mods do it for me most days ha hah ha
  26. Aegis
    In edit mode, there isn't a box that says "delete this post" ?
  27. 02blubru
    ^^^ thats the problem because there used to be.
    If that is not how ya go about deleting posts, how is it done?
  28. Aegis
    for right now, just delete everything in the box and put all dots or something. Its more work for us but at least that would indicate which posts users want to be deleted.
    It's pretty silly though, because nothing has changed in the forum in a while. Perhaps a rule sheet that was used has this parameter in it and it's overriding everything else.
    check in the "go advanced" part when you're editing your last post, see if the box is there. This is strange.
  29. TSTRBOY2004
    nothing in the advanced box.. like I stated.. oh well just do what Steph said.. delete words then put dots...
  30. 02blubru
    the "period" button works on my laptop, so that will work for me...
