Project V
Discussion in 'Modifications And Maintenance' started by yosmiley, Oct 4, 2004.
  1. yosmiley
    Alright, I'm at the point where I'm looking at taking the next step... Any suggestion and help would be great.
    This is what I have in mind but not sure what else is needed:
    Power Mod:
    TBE:
    TurboXS Turboback Titanium: T304 Stainless; 4 inch Bell Mouth
    Full 3inch Mandrel Bends; Polished Muffler w/Titanium 4 inch tip
    $1179
    Suggestion?
    EM:
    TurboXS Utec $975; http://forums.nasioc.com/forums/showthread.php?t=634986&highlight=turboxs
    TurboXS Mapswitch: $75
    What's listed on the web site doesn't seem to be complete. What else am I missing beside the Utec and Mapswitch unit?
    Port Stock Turbo:
    Matt S. Motorsport :D $$$$$ Matt, if you're available that is?
    Anything else? Header?
    Handling Mods:
    Spring:
    JDM Version 8 STi Pink
    STi (aka Groun N) Harden Strut Top Mount
    Combo:$639.00 through http://racecompengineering.com/product-susp1.htm
    Anti Lift Kit:?
    Sway Bar: Front and Rear?
    I'll be taking my time to install these unit through the course of this winter, if I have another car to run by than... if not... I'm going to shelf this project for awhile.
    Any suggestion is greatly appreciated.
  2. Musashi
    CAI
  3. Beej
    Beej New Member
    CAI?
    MN winter = CAI
  4. BlackDubRX
    BlackDubRX New Member
    LOL @ beej :D
  5. Musashi
    You guys have no idea how Vic drives! Were coming home from BIR after a full day of watching SCCA-LOL VIPERS, NASCAR'S and Vintage cars go around the track anywhere from 120mph to 170mph. And some how we ended up doing some speed testing on the way home at about 145mph. Boy was I scared! Besides this summer was not the usual warm summer we are use to having. ;)
  6. LVT
    LVT Well-Known Member
    white line has good anti lift kits, also a bigger rear sway bar like a 21-24 adjustable...whiteline, cobb, cusco has some.
  7. Substeroo
    Substeroo Well-Known Member
    Brake lines too Vic.
    But I'd say definitely those handling mods.
  8. FuJi K
    If you don't plan to run a stiffer setup, IMO I think getting larger whiteline swaybars front and rear would help a lot. You may need stronger brackets that hold the swaybar mount onto the chassis. I think whitline sells those as well....maybe not.
  9. yosmiley
    I think Matt's got a Cusco or APR front strut bar. I'm not sure if he's running anything for the rear.
    Matt, what's your take on the handling of your car at MAM with your current setup?
    Thanks for the feed back guys... Noah, SS Brake line is also going to be part of my brake upgrade. I'm waiting for Russ next Group Buy on Brakes to take adventage of slotted cryoed rotors on all four, plus brake pads.
  10. bikerboy
    Vic:
    tbe and utec, your good there. The problem is that the stock injectors are <font size="4">maxed</font id="size4"> out. Any further boost will require larger injectors. IMHO injectors are a must!
    "What's listed on the web site doesn't seem to be complete. What else am I missing beside the Utec and Mapswitch unit?" Tuner
    Stock turbo PNP of course I will do that.
    Headers? if you want to spend the money sure. But if your not going full out I would say port match the stockers and maybe send them out to be coated. I would coat the downpipe as well. That should run under 200.00
    Handling:
    Springs and top hats and ALK are all good.
    The problem is the back of the car is like a marshmellow!
    IMHO: A rear sway bar and heavy duty mounts are a good step. Before I would do anything with a front bar I would get the rear sorted out. I would look at whitelines Lateral links and ladder bars to relpace the pathetic stock pieces. And look at a diff locking kit or replacing as many bushings back there as you can.
    M
  11. bikerboy
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by yosmiley
    Cusco bars F & R
    see my reply above as these parts were left over from my WRX
    My take on the car is as above. My time at MAM was ok but the tires I have are not track friendly.
  12. yosmiley
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by bikerboy
    M
    I'll check with vendors on the Whiteline lateral links and ladder bars to see what's out there and who's offering what.
    Differential locking kit? I'll check in Nasioc/I-Club on the bushing replacement... suggestions of any company out there that may have a full set for the car?
  13. bikerboy
    Yes it locks the rear diff carrier to the car. just one more place that the rear end has slop.
    IIRC subaru has a grp N bushing kit I think it is pricy. There are others but I need to find the info
  14. subi_2.5rs
    subi_2.5rs New Member
    take my car for a ride then you'll know vic....
  15. WRX1
    I think energy suspension has a COMPLETE bushing kit. I think it is every bushing in the car. I will do some digging again to see if I can find it. I would definitly set up the injectors, with the utec it is easy to dial back the fuel and you will be good to go. Even on the stock turbo, and if you plan on a little bit bigger turbo, the injectors are still good.
  16. yosmiley
    Awesome! Russ thanks for that piece of info. on the Energy Suspension. I have heard of them and was hoping that if I was to look for a full set, Energy Suspension would have the setup I'm looking for.
    Makes me all quizy knowing that I can get bigger injector and control it using the Utec. Would that also help with my MPG since I can control the flow of gas? well it also depends on my driving style of course.
    Fitting a bigger turbo (homer drool):p in later w/o replacing the new injector after the upgrade is a plus. Injector recommendation?
    I know I won't be going there for awhile until I run the stock turbo down to it's last breath... through normal driving that is ;)
  17. bikerboy
    No it will not really. the stock ecu shoots for 14.7 AFR in closed loop. So lets say at idle it has a .12ms PW to get 14.7 with 480 cc injectors. Lets say it shoots 5cc's to get that 14.7.
    Now you go with a larger injector lets say 810cc'c now the PW needed to get the 14.7 AFR will be .06ms to deliver the same 5cc's of fuel to get the 14.7 AFR
    Make sense?
    Where you will see a gain in mileage is when you are on boost all the time since the car runs rich we can pull the extra fuel to get to the target AFR we descide.
    Modified stock ones are 210.00 ? IIRC
  18. yosmiley
    Sounds like a plan.
  19. Musashi
    "Modified stock ones are 210.00 ? IIRC"
    Yeap, I like that idea! :cool:
