Protune set up!
Discussion in 'Modifications And Maintenance' started by shorty5198, Feb 2, 2007.
  1. shorty5198
    shorty5198 New Member
    Well I finally got my protune set up with DB. Its going to be tuned next weds with the following mods-
    3" Free Flow TBE
    SF intake
    new top mount
    850cc Inectors
    NGK step colders
    My goal is somewhere in the low 300's wheel. Then after that i'm planning on setting up another date for the alky to be put in. I dont expect too much out of that but hopefully i'll be able to run a little more boost. I'll post my dyno numbers after i get the tune. w00t!
  2. Sogonerg
    Sogonerg Anteater
    what turbocharger are u using?
  3. Speedemon
    Speedemon Well-Known Member
    Knock knock
    whos there
    knock know
    ohh
    i hope you have more mods then that if you want 300whp...
  4. Sogonerg
    Sogonerg Anteater
    ^that's why I asked...Any Stock VF Turbo won't get u there...
  5. AspitFire
    are you kidding? ive seen many vf's put down 300 or more and most put down 280 and up
  6. Sogonerg
    Sogonerg Anteater
    With our local Dyno's it won't hit that 300whp...On a Dynapack, but not on our Mustang or DD
    We got any dynapack locals?
  7. wall of tvs
    I don't think so.
  8. Sogonerg
    Sogonerg Anteater
    unless it is on a dynapack...good luck hitting 300whp on any VF
  9. shorty5198
    hmm well i was looking at cobbs stage 2 map for the STi and it says it puts it at 350 hp, to the crank obviously. I'd say that there is about a 20% loss with awd and that means that i would have to make 10 more hp to the crank than a base map for my car. I think around 300 wheel is attainable. i guess we'll just see. Oh and i talked to the guys at db and i'm just going to have it tuned as is on weds without and fuel upgrades and plugs because thats a whole nother day of work itself. The reason my injectors are so big is if i ever do plan on upgrading turbos down the line all i'll have to do is get the turbo itself..
  10. shorty5198
    you think i'm gunna have detonation?
