We have a bunch of PTE in stock and since we bought these at the old dealer pricing we are willing to pass the savings on to you! Contact us before the end of the month to get the absolute best deal you'll find on any of the below PTE turbochargers, if you do not see what you're after simply drop us an email or a call at the shop and give us an opportunity to save you huge $$$$ PTE 003-5431-T3-.63-5B Entry Level Turbocharger - 5431E MFS "E" compressor cover 3.0" inlet/2.0" outlet Turbine housing: - T3 .63 A/R with 5 bolt discharge (without wastegate hole) 1 PTE 003-5831-T3-.63-4B PTE Entry Level Turbocharger - 5831 MFS "E" compressor cover 3.0" inlet/2.0" outlet Turbine housing - T3 .63 A/R with 4 bolt discharge 2 PTE 505-5858 B-VB-.64 PTE PT5858 Turbocharger, Ball Bearing, "Ported S" compressor cover 4.0" inlet/2.5" outlet -- V-Band Inlet - .64 A/R 3 PTE 505-5858-T3-.82-4B PTE PT5858 Turbocharger/ Journal Bearing - "Ported S" compressor cover 4.0" inlet/2.5" outlet Turbine housing - T3 .82 A/R with 4 bolt (2.5") discharge 1 PTE 505-5858-T3-VB-63AR PTE PT5858 Turbocharger/ Journal Bearing - "Ported S" compressor cover 4.0" inlet/2.5" outlet PTE 505-5862BB-V-.64 PTE PT5862 Turbocharger, Ball Bearing, "Ported S" compressor cover 4.0" inlet/2.5" outlet Turbine housing - V-Band inlet .64 A/R with V-Band discharge 1 PTE 505-6262-T3-.63-4B PTE PT6262 CEA Journal Bearing Turbocharger - "Ported S" compressor cover 4.0" inlet/2.5" outlet Turbine housing - T3 .63 A/R with 4 bolt (2.5") discharge 2 PTE 505-6262B-T3-.63-4B Precision Turbo 6262 Ball Bearing, Ported S cover, T3, 4 bolt 4" inlet 2.5" outlet w/ .63 A/R 1 PTE 505-6266 B-T3-82-4B PTE PT6266 Turbocharger, Ball Bearing, "Ported S" compressor cover 4.0" inlet/2.5" outlet -- T3 - .82 A/R - 4 Bolt 2 PTE 505-6266 B-T4DIV-1.0 PTE PT6266 Turbocharger, Ball Bearing, "Ported S" compressor cover 4.0" inlet/2.5" outlet -- T4 Divided - 1.0 A/R with 3 5/8" V-Band discharge 1 PTE 505-6266 B-VB-.82 PTE PT6266 Turbocharger, Ball Bearing, "Ported S" compressor cover 4.0" inlet/2.5" outlet -- - V-Band inlet .82 A/R with V-Band discharge 2 PTE 505-6266 B-VB-.82-BLK PTE PT6266 Turbocharger, Ball Bearing, "Ported S" compressor cover 4.0" inlet/2.5" outlet -- - V-Band inlet .82 A/R with V-Band discharge 1 PTE 505-6266-T3-.82-4B PTE PT6266 Turbocharger, Journal Bearing, "Ported S" compressor cover 4.0" inlet/2.5" outlet, - T3 .82 A/R with 4 bolt (2.5") 3 PTE 505-6266-T4DIV-1.0 PTE PT6266 Turbocharger, Journal Bearing, "Ported S" compressor cover 4.0" inlet/2.5" outlet - T4 Divided - 1.0 A/R with 3 5/8" V-Band discharge 1 PTE 505-6466 B-T4DIV-1.15 PTE PT6466 CEA Turbocharger - Ball Bearing"Ported S" compressor cover 4.0" inlet/2.5" outlet --- T4 Divided - 1.15 A/R 1 PTE 505-6466 B-T4DIV-84 PTE PT6466 CEA Turbocharger - Ball Bearing"Ported S" compressor cover 4.0" inlet/2.5" outlet --- T4 Divided - .84 A/R 2 PTE 655-6766-T4 TAN VB-.81 PTE PT6766 Turbocharger, Journal Bearing, "Ported H" compressor cover 4.0" inlet/3" outlet --- T4 TAN V-BAND - .81 A/R 1
