Q; Subaru 2.5 shortblock with 2.0 heads BIG PROBLEM IM RUNNING THIS SETUP
Discussion in 'Modifications And Maintenance' started by BugIedIzzy, Feb 14, 2011.
  1. BugIedIzzy
    BugIedIzzy Well-Known Member
    So i wanted to know if this is a big problem, 2.0 heads bored out width not depth to a 2.5. The confusing part is I was told the hybrid setup was a solid setup and a lot of people ran this setup with great success! But my real question is, is this style of heads needed or is someone trying to make a buck!?!?!?!
    Price: $400.00
    Import Image Racing will beat or meet any competitors pricing!
    The Problem: As most people know, when you run a Subaru 2.5 shortblock with 2.0 heads, the compression ratio is too high to run safely and efficiently especially on pump fuel. The common approach to resolve this issue has been to use a thicker head gasket to try to bring the compression ratio down. While this can bring the overall compression ratio down, it is by no means ideal. The resulting combustion chamber shape remains inefficient since you're leaving the 2.0l chamber in the heads untouched. You are in essence reducing the effectiveness of the quench area and introducing several sharp edges to thecombustion chamber that can build up heat and cause knock. This makes the engine less efficient than a full EJ257 with EJ257 heads. While some of these setups can tune ok, they generally experience inconsistencies under sustained full throttle operation. Drivability and fuel economy are also adversely affected. Some have also tried using custom pistons to bring down the compression ratio, but this has a very similar effect to a thicker head gasket.
    Our Solution: Instead of using a thicker head gasket or low compression pistons, we decided to try something a bit different. We worked closely with our machine shop to carefully map out the combustion chamber of the EJ257 STI head and create a CNC program to replicate the exact same chamber every time. Using this program, we then set up the 2.0l head castings in the CNC and machine out an exact copy of the 2.5l combustion chamber into each 2.0l head casting. We are then able to use a quality OEM head gasket and maintain the exact compression ratio and combustion chamber shape of a complete STI engine. This improves the effectiveness of the quench area and the overall efficiency of the engine.
    The results with this approach show big improvements not only in overall power output, but especially in terms of crisp, smooth off-boost drivability and torque. We've also seen a significant increase in fuel economy as compared to a standard hybrid build. From a tuning standpoint, the difference is so significant that we had to spend quite a bit of time building new base maps for these builds. Under low load conditions, these setups can run as much as 15-20 degrees more timing advance than a hybrid build with a thicker head gasket. This was a great thing to see as we end up with a timing curve much more similar to a 2.5l STI rather than a 2.0l WRX.
  2. AWDimprezaL
    Lots of folks running the hybrid without issue, many for many thousands of miles. Do not concern yourself with things like this.
  3. SvxAL
    SvxAL Member
    I had a hybrid build it was awesome! just get it tuned and you'll be good!
  4. BugIedIzzy
    thanks they had me going for a sec
  5. curly2k3
    if you read up on it all on nazicock, it does make a difference, but its not NEEDED
  6. FuJi K
    They make the combustion chamber a replica of the EJ257. This allows for use of the pistons made for the EJ257. It also allows for similar tuning style to the 2.5L since it is the same combustion chamber style. It pretty much is like an EJ257 for internal specs. This does make it easier to buy off-the-shelf pistons since almost all are made for the EJ257 anyway.
    Bore matching is really good to have. It doesn't have to be an EJ257 shape. The D25 EJ255 doesn't have the same combustion chamber as the B25/V25B/W25 EJ257 heads. The chambers of the D25 heads are 97mm wide where the EJ257 are 99.5mm wide.
  7. readymix
    You still don't need it. I'm running the EJ257 case with 257 standard sized Mahle pistons with stock mill WRX 2.0 heads without issue. And I've been doing so now for nearly 4 years.
  8. greaser
    greaser New Member
    Ok newb question alert. This is for a N/A set up or turbo?
  9. Mr.Tran
    Mr.Tran Well-Known Member
    I'm gonna assume turbo.
  10. BugIedIzzy
    yes its a turbo setup, 2002 wrx
  11. Tash
    Tash Well-Known Member
    so why dont you post up your other question of your ****ty gas milage!
  12. BugIedIzzy
    getting 157mpg in a 2002 wrx. ¿13gal tank? stock wrx injectors, TDO4, 2.5 block 2.0 heads, 1572 miles on the block changed the oil at 1500. been trying 2 drive conservative. im thinking its the turbo seeing its fully spooled at 2900 rpm don't know when the actuator opens for the exhaust. Only running 11 for boost. I drive about 40 miles to work every day and this is starting to get to me!!
  13. AWDimprezaL
    Who tuned it? I assume you mean 15 mpg, not 157. Try proof reading before hitting reply.
  14. olegrad
    olegrad Well-Known Member
    I think he meant 157 miles from a full tank of gas.
  15. AWDimprezaL
    SHHHHHHHHHHHHHHHHHHH, I like to be a dick, just agree.
  16. readymix
    Stock fuel tank is 16.9 US gallons, not 13.
  17. JasonoJordan
    are u sure about that. ive been dead empty in my 02 wrx and never put that much in my car.
  18. Nuke
    15.9 gallons
  19. JasonoJordan
    yea that sounds right,.
  20. readymix
    Doh! Yeah, 15.9. I usually round up to 16 in my head, I think that's why I put 16 instead of 15.
  21. BugIedIzzy
    sorry i usually fill at a Lil under a quarter left. i only remembered seeing 13.
  22. BugIedIzzy
    map tuned, and 157 to a full tank
  23. readymix
    I'm guessing you mean till the fuel light comes on? Typically the light comes on when you have between 3 to 4 gallons left in the tank. Which if we go with the 3gal mark, you're getting around 12mpg. What is your daily commute, and how long do you let it idle before driving? That still sounds pretty terrible.
  24. BugIedIzzy
    highway for 38 miles and traffic lights for 2 miles. i let it idle for 5-10 min depending on weatheri
  25. Lowrider
    Lowrider Well-Known Member
    -My work/home commute is approximately 20 miles to and fro. City driving
    -I usually have a full tank monday morning, but by friday my tank is down to 1/4 mark.
    -Thus, i probably get 120 miles from a full tank just from city driving.
    -Highway ~250miles (could be less) on full tank ( if im nice to stay out of boooost)
    * Stg 2 STi
    * E85
    * ~830cc injectors
    * 2-3mins of idling in the morning & evening = 6mins Total
    She is one gas guzzler *sigh*
  26. Nuke
    You're on E, you can't complain or sigh
    Haha
  27. Lowrider
    ^^ Yes sir,
    However, do you know how much difference there is in consumption between E & Octane?
  28. Nuke
    Average 30%
    But with a good right foot, you can get decent mileage with E. Lol but who has that, especially with a subaru.
  29. Back Road Runner
    Why would you use 2.0L heads in the first place? Isn't the 2.5L SOHC head superior to everything else? It seems silly to even start with this approach, especially for turboed cars where you're already going to be tossing in forged pistons anyways to get whatever compression you want. Heck, if you wanted off boost power, you could probably even run cams suited for a NA motor which from my understanding versus turboed cams is something akin to a big turbo cam anyways.
    I guess I just don't see the point of the 2.0L heads in the first place.
  30. AWDimprezaL
    Wow, no, the SOHC 2.5 head is terrible for turbo, just ask bielke55 and munkyking, they just werent made to make big HP. Also, n/a cams have too much overlap to make big power in turbo applications, basicly you are just blowing boost right back out the exhaust. Do a bit of research, the MAIN reason for running the 2.0 head on the 257 is because its easy, and you dont have to mess with the AVCS that the 257/255 heads have/use, plus the little boost in CR (and the bigger displacement) make it much more enjoyable off boost. Have you ever driven a 2.0 wrx, even stage 2 and tried to stay out of boost? They are pooches.
