Quesdion for you nice people...
Discussion in 'General Subaru Discussion' started by srodgers7170, May 24, 2005.
  1. srodgers7170
    Online
    srodgers7170 Guest
    Here is my dilema. My XT has one of those retractable trunk covers that pops into place. I think it is the same as those available on the WRX wagons etc. This thing rattles like no tomorrow. It also buzzes when I turn the stereo up. There is a modest yet totally servicable sub in the back.
    Unfortunately, for work, I have a laptop and I find myself needing to keep it concealed in the trunk so I really don't want to ditch the trunk cover if possible.
    Any of you have any thoughts on how to quiet this silly thing down? I am pretty sure the rattling is coming from the actual spring loaded spindle like those on a set of blinds that one would have on a window.
    Thoughts?
    Stan...
  2. AWDimprezaL
    Monticello.
    find out where its rubbing and wrap either electrical tape (if you have black interior) or clear tape of some sort if you have tan, should work
  3. Zola
    Zola Well-Known Member
    St Louis Park
    Most of my rattles (and there are LOTS, ugh) have been solved with some combination of foam and/or silicone sealant.
  4. DISCOPOPE
    DISCOPOPE Well-Known Member
    my wife's cross county does the same thing.
    there actually was a kit that volvo sent out for this.
    it was 2 pads of self adheisive cork gasket material. :eek:
    anyway, it worked..
    just find where its rubing.
  5. kickin_81
    kickin_81 Well-Known Member
    St. Paul
    Is this peice the cargo cover? Mine doesn't rattle. As mentioned, foam can be used to tighten the ends up. Go to Menards/Home Depot and buy their strips of foam designed for air conditioning systems. It's only $2-3. Cut an inch off and wedge it in the loose spots of the cargo cover. Then save the rest for what I did below. :)
    (I've purchased a strip of this for my old GC and wedged it in between my radiator and the frame to act as a radiator cover which prevents air from going over my radiator.)
  6. srodgers7170
    Online
    srodgers7170 Guest
    I don't know for sure if it is the ends that clip into the plastic panels in teh back of the car or if it is the actual spindle around which the cargo cover winds when open.
    Ugh...
  7. Grimm
    Grimm New Member
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by srodgers7170
    Ugh...
    Put a few peices where you think it is rattling, if sound contiues use in more locations/differnt locations untill sound is gone. I had a rattle in an old wagon that I had. Took forever to find the sound.
    Good luck.
    Passanger in the back helps they can point it out.
  8. scoobydreamin
    scoobydreamin Well-Known Member
    Inver Grove Heights, MN
    Just turn the stereo up louder!
    Seriously some latex tubing or self sticking foam will do wonders.
  9. srodgers7170
    Online
    srodgers7170 Guest
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by scoobydreamin
    Just turn the stereo up louder!<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
    Actually that is part of the problem> Because the sub is in the back of the FXT both it AND road bumps are rattling this thing a lot.
    Thanks for the tips guys. I will hit it with some foam here and there and see if I can isolate it.
    Other than that, this XT has been a dream. Just ask the guy in the 330XI that got a good look at my rear license plate the other day.
    Stan...
  10. Deride
    3m Strip Calk, solves all problems. Can even use it to seal subwoofer enclosures. Just can be messy if you dont use it properly.
