Question about MP3 in 02 WRX
Discussion in 'General Subaru Discussion' started by strangefamous, Sep 17, 2008.
  1. strangefamous
    Anyone know if a place where i can get a cheap little plug in for it? Am I even able to do this with the stock 6 disc in dash? all details would be greatly appreciated.
  2. Paul Revere
    JL Audio makes whats called a "Clean Sweep" http://mobile.jlaudio.com/products_cleansweep_pages.php?page_id=94
    May be worth looking into, for quality and sound it more than likely can't be beat. I found these when I was looking into trading the WRX for an LGT, since the LGT has a integrated stereo head unit this seemed like the best option for an after market woofer and amp/amps setup plus the Ipod plug in.
  3. prezawagon
    prezawagon Well-Known Member
  4. Paul Revere
  5. gc8
    gc8 Well-Known Member
    Well is there an AUX input in the back of the stock deck? If so, just go buy a AUX cable with two male ends and viola
  6. strangefamous
    Hmmm. not sure. I'll check tonight. Thanks guys.
  7. SenorSubie
    SenorSubie Well-Known Member
    I'm pretty sure there isn't an AUX input in the rear of the deck. On some of the foresters with the newer 6cd changer headunits there is a 13 pin connector allowing you to fab up your own aux cable with that end on it to plug in and then play a "silent cd" track. I actually made one for my car (I'm using an 02 6cd changer hu from a wrx) but when I pulled it out in the location where I thought it would have the 13 pin round connector I found a different rectangle one. So it's possible that someone could try doing the same type of thing with that end. Maybe a Saturday project for me if I have time
    Here's a picture.. nothing pretty but if you wanted to use black wire etc it would look fine.
    I'm pretty sure the 13 pin end was this:
    http://cgi.ebay.com/13-Pin-Din-Conn...ryZ96966QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  8. Ryan
    Ryan Sled drifting master
    I can tell you this right now there is no way to hook up an ipod/mp3 player to your stock deck like some stock decks will (such as ford). Your only option is what Joel (prezawagon) said.
    If you have an ipod, I strongly recommend this deck: http://www.alpine-usa.com/US-en/products/product.php?model=iDA-X001
    It is what I have and I bought the same thing for my wife's car. Look online and you should be able to pick it up for cheap. I found it at best buy on clearance about 8 months ago for $80, which was a steal. The newer models are even better. It is worth the money, trust me.
    If you want to see it in action, I can try to meet you down at firestone at some point. Just PM me.
  9. pksublime
    pksublime Well-Known Member
    ted and i (and maybe others) have the jazzy engineering kit and love it
  10. Paul Revere
    And why can't he use what I stated?
  11. blackozone
    Because you're Chet.
    Seriously, there is no Aux plug on the back. Get one of the "Silent CD" units and run with that. 02 decks are limited.
  12. prezawagon
    Probably because he is looking for something cheap. By the time you buy that dsp and the source expander for it, I'm sure it would cost more than buying an aftermarket head unit. Even the Jazzy Engineering piece is pushing the cost/benefit ratio of just going to aftermarket, unless you really want to keep the stock head unit.
    But, that does look like a great option for cars where the factory stereo is really integrated into the dash and not easy to replace.
  13. driftin240
    driftin240 Well-Known Member
    I have a Pioneer MP3/Ipod deck. Pretty much the best way, although you would be replacing your head unit. Works great though, and no static bs to deal with.
    Pioneer DEH-5000IB
  14. Vila
    Vila New Member
    I used the cassette adapter in my '02 WRX. Except, I inserted the cassette adapter with the faceplate removed. Ran the cable behind the facepalte toward the glove box. When I want to connect, open the glovebox and pull the connection out. Never remove the cassette adapter or touch eject.
    No one can tell you have a hidden cassette input adapter.
    Vila
  15. Paul Revere
    Side note I have an Alpine deck with a direct cable to my Ipod that I bought for around $220 last year at Ultimate Electronics. LOVE IT!
  16. PRA4SNO
    PRA4SNO Well-Known Member
    vila, thats a great idea. thanks!
  17. PRA4SNO
    please say your first name is bob btw
  18. a14ypzz
    a14ypzz New Member
    QUestion for u guys that have aftermarket decks installed
    did u guys buy adapter brackets?
    or how exactly did u guys fit it if u can provide any pictures
  19. Paul Revere
    IIRC mine just screwed into the existing bracket, but I did buy a pocket to fill in the gap.
  20. a14ypzz
    a14ypzz New Member
    ah im interested on how or where u bought the pocket to fill in the gap
  21. Paul Revere
    Ultimate was out of stock so I got it from a small hole in the wall car audio place in Richfield. I believe some other cars like the Lancer and Corolla may use the same one, you could always use Crutchfield.com or SoundDomain.com.
  22. Ryan
    Best buy IIRC
  23. a14ypzz
    a14ypzz New Member
    kool thanks guys i'll try and look for it ive had a pioneer for a while now but havent had time to install it bcuz of school and work and also cuz i couldnt find something like that
  24. Vila
    Vila New Member
    Oh my name's Bob all right...
