quick question...
Discussion in 'Modifications And Maintenance' started by WRXEcho, Jan 28, 2008.
  1. WRXEcho
    WRXEcho Well-Known Member
    I have a Perrin PSRS installed that I think is creating the screaming noise from the 7th level of hell in my car. I believe my version has the grease fittings on them. So, I'm wondering what kind of grease I should squeeze into there. Something water resistant I imagine...
    Your advice is appreciated :)
    Thanks,
    - Justin K.
  2. Iroc-Z
    Iroc-Z Well-Known Member
    WTF is a PSRS?
  3. Scuba Steve
  4. WRXEcho
    the wrx one looks a bit different than that one...but yeah, that.
  5. Dynapar
    I think that most people use a white lithium grease. I will need to double check that.
  6. Scuba Steve
    yup, just an illustration for IROC-Z
    here's something I found, but i don't believe anything special like this is really needed
    Prothane Super Grease contains versatile water-proof, non-melting Teflon and is formulated to seal out water and to lubricate under the most adverse conditions. It’s superior adhesive and extreme pressure qualities, combined with it’s urethane compatibility makes it the only one to use.
  7. WRXEcho
    that's what I've been reading, but I want to be sure so that I don't have to regrease the damn thing every month from water getting in there.
  8. WRXEcho
    I suppose maybe some synthetic suspension grease, or the white lithium stuff would work then...Thanks guys :)
  9. WRXEcho
    sooo...I got a grease gun and some marine grease...:) I figure that should stave of the water.
    AND IT WORKS!!! NO MORE SQUEAKING FROM HELL!!! YAY FOR ME!! :) :banana:
