Quick Question????...
Discussion in 'General Subaru Discussion' started by TheWRX, Jun 13, 2005.
  1. TheWRX
    TheWRX Well-Known Member
  2. kickin_81
    kickin_81 Well-Known Member
    I have no experience with the installment of AWD shocks into an FWD chassis, but I warn you that it may not turn out pretty in the end. Try to find a set of FWD GR-2 shocks instead.
    The KYB GR-2 Shocks are 15% more stiff in comparison to the OEM RS shocks (which are a bit stiffer than the L shocks already). KYB told me that through an email a couple years back. Because they're stiffer, you'll get slightly better handling at the cost of shock dampening. In other words, your car will feel road bumps a bit more. :p
  3. TheWRX
    Thanks fong for ur answer.
    COMEON GUYS I KNOW MOST OF U KNOW ABOUT THIS GARBAGE, SO SHARE}:)
  4. FuJi K
    You know, IF you can make your FWD into AWD and still be able to USE the stock strut, I don't see why a AWD strut won't work for a FWD in the same chassis GC/GM/GF.
  5. Chin
    Chin Well-Known Member
    I think the only concern would be the valving, but I really doubt there is a difference. Would KYB revalve for the slight weight distib. difference? Not if they want to make money... :eek:)
    Not a guarantee, but I would think you would be fine.
  6. subi_2.5rs
    subi_2.5rs New Member
    it will work.....becuz the fwd shock are the same as awd....
  7. TheWRX
    Thanks guys.
