rack and pinion
Discussion in 'General Subaru Discussion' started by subaru, Mar 23, 2010.
  1. subaru
    subaru Well-Known Member
    Is it hard to change a rack and pinion(03 wrx). 277 if i do it my self 800 from mechanic so defiantly want to do it my self unless its really hard.
    thanks
  2. Shibbs
    You will need an alignment after doing it, also flushing your ps fluid is usually a good idea as well.
  3. TheSnowman
    TheSnowman Well-Known Member
    ^^ this is all true, it shouldnt be to hard just be sure to drain the system before you remove the rack.
  4. Scuba Steve
    there's some monkey busy involved....but doable and worth the 500 you'll save in labor.
  5. subaru
    Thank you ordered it and it will be here Saturday
  6. TheSnowman
    good luck with your install
