Racket from rear end of 07 wagon
Discussion in 'Modifications And Maintenance' started by Soupboy, Aug 28, 2007.
  1. Soupboy
    Soupboy Well-Known Member
    So, my new wagon has started make an odd, unpredictable mechanical racket coming from the rear end - right side, I think. It tends to do this as the suspension balance shifts going around turns, between shifts or during deceleration. The noise is not always at the same volume, duration or frequency.
    I was driving *sportingly* on some gravel/rock roads over the weekend and I'm thinking that maybe some rocks got into the brake or suspension components some how.
    Has anyone experienced this?
    Thanks in advance,
    Sean
  2. hella_sti
    hella_sti Well-Known Member
    small rock in the coil of a spring?? Get up under there and check it out!
  3. Soupboy
    That's what I *hope* it is. Wondering if it might be something more dastardly.
    It should be up on a lift soon so I can better inspect then.
