Radiator fan not spinning?
Discussion in 'Modifications And Maintenance' started by cloudpost, Jul 26, 2014.
  1. cloudpost
    cloudpost Member
    Last night while I was stuck in traffic, my idle was at 2k and my engine temp was raising. I turned off the car when it reached the 3/4 line. Once I got into some open air I had no problems at all. I am going to burp for bubbles right now, but I also noticed only my right fan (when staring at the bay from the front) only turns on with the A/C. The left one doesn't spin. Is it supposed to?
    2003 wrx engine.
  2. phi11
    They work separately and a fan failure should generate a CEL.
    when discribing the locaion of a part, do so as if you were sitting behind the drivers wheel.
  3. JasonoJordan
    Could have blown the fuse I had that issue.
  4. iand464
    iand464 Well-Known Member
    I have a extra rad fan nib aftermarket stock replacement if you need to purchase a new one. If you need to check it plug the green test/flash connectors by drivers left foot together and it should cycle on and off like crazy
    cloudpost likes this.
