Radiator fans not coming on in 2008 Outback?
Discussion in 'General Subaru Discussion' started by pcwerk, Feb 3, 2018.
  1. pcwerk
    pcwerk Well-Known Member
    Hello again,
    well the 2008 Outback i got my wife is running great (maybe need an
    alignment in the near future) but i have concerns that the radiator fans
    never turn on. she just got back from a 1 1/2 hr trip (one way) from her
    mom's and once again they were not on? her old 1999 Outback had fans
    that would come on all the time. the car is not overheating at all, however
    she does describe the heater as "very warm" (which of course, she likes).
    the car had front end damage and a bumper and new radiator was installed.
    am i worrying for nothing or could there be a problem here? thanks for any
    and all advice! jim
  2. tangledupinblu
    I wouldn’t worry about it for now Jim. If it IS an issue, you’ll find out this spring/summer.
    -Josh
    pcwerk likes this.
  3. pillboy
    Maybe the body shop didn't install fans.
    pcwerk likes this.
  4. pillboy
    I've never really paid any attention, but would setting the HVAC to front defrost, which turns on the AC compressor to dehumidify the air, force the fans on like it does in the summer when you turn on the AC?
    pcwerk likes this.
  5. pcwerk
    i can check. but yes, it definitely has fan.
  6. pcwerk
    thanks! it is such a nice car, i just don't want to screw it up. i guess as you
    say i won't worry until it starts overheating...
  7. tangledupinblu
    Yes.
    pillboy and pcwerk like this.
  8. tangledupinblu
    It could be as simple as a fuse as well. But ultimately, in my head, if it’s not overheating, then maybe the fans just aren’t cycling because they don’t need to.
  9. phi11
    It could even be that the fans are not plugged in!
    tangledupinblu, pcwerk and pillboy like this.
  10. pcwerk
    yes, i will check that later today. the guy that did the bodywork and installed
    the radiator texted me to check that last night. (it's good to have an honest person
    to deal with, when i asked him a few days ago if he had done a tune-up since the car
    runs so well, he replied "not really" and made some recommendations to do at
    110,000 mile service ;)
    thanks!
  11. pillboy
    Modern cars really don't have "tune-up" requirements like back in the points and condenser / carburetor days. As long as you keep up on the MANUFACTURER'S maintenance schedule (not a dealership maintenance list) you're good.
    Cotts612, tangledupinblu and pcwerk like this.
  12. pcwerk
    i checked the fans and they are plugged in and the HVAC trick didn't work.
    i think i'll just monitor it and not worry until it starts overheating...
    jim
  13. tangledupinblu
    Jim, have you tried running the AC? You SHOULD be able to get the fans to turn on with running the AC compressor.
    pcwerk likes this.
  14. pcwerk
    yes, i turned the ac on and still no. i'm getting an owners manual
    off ebay Friday maybe i can find where the fuse is to see if its blown?
  15. subie-roo
    subie-roo Well-Known Member
    Checked the manual for my 08 Outback this morning. Fuse 5 (25A) in the engine compartment is for the fan, I would also check fuse 22 (15A) in the passenger compartment. Hope you get it figured out.
    pcwerk likes this.
  16. pcwerk
    thanks! I will check when I get home...
  17. tangledupinblu
    Fuses are pretty cheap. Pick up a variety pack on the way home if you don’t have some already.:thumbup:
    pcwerk likes this.
  18. Krazylegz1485
    Online
    Or swing by the local U-pull and score a pocket full...
    Cotts612 and tangledupinblu like this.
  19. silver03
    wheelbarrow full!
  20. Krazylegz1485
    Online
    Hi, I'd like to purchase all of the fuses from all of the cars, please.
  21. silver03
    That will be two dollars please
  22. pillboy
    And you still won't have the one you need.
    silver03, tangledupinblu and pcwerk like this.
  23. pcwerk
    Welp the fuses looked good. I thought I had hit paydirt when I saw no fuse in one place marked fan...but it said to use only in a 3L engine and I’m pretty sure mine is 2.5L. I’m going to chat with my mechanic after work tomorrow...I’m sure he’ll be thrilled to see me ;)
  24. pillboy
    Bad fan relay?
    pcwerk likes this.
  25. pcwerk
    possible. i will probably let my wrench figure it out. found a pretty informative
    video on youtube. never thought of turning the fans to make sure their not seized up!
  26. pcwerk
    well for folks following along, i dropped by my mechanic's shop today
    and he didn't think it was an urgent issue (good, 'cause i want him to
    get on the 1999 Subaru's headgasket Monday) but said it could have the
    thermostat stuck open? he said he would need to test it out but thought
    a check engine light would be on if it was real serious...of course, i will
    continue to monitor the temp. thanks again for all the input!
  27. pcwerk
    a follow-up, as i hate threads that never come to a conclusion, finally took
    the wife's 08 Outback to have AC check and fan issue. replaced the fan motor
    and fan as the old one was bad. says the shaft was bent causing the blade to wobble.
    (kind of irks me that the guy who sold me this car probably utilized used parts
    for the whole rebuild!). anyway, drove it the two blocks home and they fans were
    both on and working as expected ;)
    Stormtrooper1 likes this.
  28. pillboy
    Same here.
    Glad you got it sorted.
    pcwerk likes this.
