Pics upon request as there is alot of stuff Honda: D16y7 5 speed tranny (works good no grinds)- 75$D16y8 5 speed tranny (3rd gear grind)- 50$D16z6 stock oil pan- 5$D16 axles (less then 1000 miles)- 75$B series intermediate shaft (male x female)- 25$D16z6 intake manifold w/ throttle body & fuel rail (x2)- 25$/eachDNA Motoring strut tower bars front and back (red)- 25$D16y8 Valve cover (x2)- 25$/eachOBD1 ecu to OBD2 jumper harness- 25$OBD2 ecu to OBD1 jumper harness- 25$Stock z6 throttle body w/ newer map and tps- 15$Stock HF exhaust manifold- 5$Stock y8 cam gear- 1$B series AEM fuel rail (truck bed liner spray painted)- 25$Almost brand new aftermarket 68mm tb w/map & tps- 100$OBD2 Gsr ecu (p72)- 30$Brand new Golden Eagle pro series D16 fuel rail (black)- 100$Blox stage 2 y8 cam w/ stock y8 cam- 150$for bothInnovative rear mount in eg- 50$Autometer pro comp ultra lite oil psi gauge (electrical/no sender) 25$Autometer pro comp ultra lite a/f ratio gauge- 10$New Eg civic front ball joints (lower) TRW part# 104216- 25$ for bothD16 vtec solenoid- 5$Hasport 3 post driver mount- 50$3- misc rear t brackets (all d i believe)- 5$eachTial wastegate springs 1-yellow 1-green- 2$eachStock B series 3 bolt driver mount with red energy inserts- 25$Ebay tranny and rear mounts for hydro eg d series- 25$D series skunk2 pro intake manifold (bare)- 150$STR billit 68mm throttle body w/tps & map- 100$13" rims w/ 22"x 8" slicks 4x100 (lots of life left) Subaru:Helix High flow catted 3" downpipe- offerBPM Tmic (THICK) w/ silicon y pipe- offerGreddy catch can (no lines)- 25$Stock 04-05 wrx tmic- 75$Grimmspeed 3 port BCS 02-05 wrx- 100$NRG quick release wheel w/ NRG hub- 300$K&N drop in filter- 10$02+ gauge surround pod (two spots for gauges)- 30$04-05 wrx momo air bag (red inside)- 100$Wrx red momo shift knob- 30$Cobb intake pipe w/ filter & maf- 100$IHI vf-30 turbo (no shaftplay)- 200$Perkins turbo part # 2674A402 (no shaft play)- 200$ Text (218) 731 5017 is preffered... can ship or meet up depending on location THANKS Items located in Fargo ND
It is still available... And somewhere around the 500 ballpark is what I've been told but open to pm offers!
Bump! Will change more when I get to a computer but for now Slicks- 200$Obo Blox y8 stage 2 cam- 100$ NRG wheel and quick release hub- 200$ Huge BPM tmic- 200$ Subaru GM 3 port BCS- 50$
