Random tips for you guys
Discussion in 'General Subaru Discussion' started by kickin_81, Nov 13, 2005.
  1. kickin_81
    kickin_81 Well-Known Member
    St. Paul
    Thanks to Mushashi and his link to northstarbmw.org, I was able to read and obtain some knowledge from their tech articles. http://www.northstarbmw.org/index.aspx?ns=TechArticles#d
    1) I now know what to do to my car in preparation for the winter.
    2) I now know Amsoil 5w30 and 10w30 beats the oil competitors hands down.
    3) I now know when pushing caliper pistons in for new pads, loosen the bleeder screw to expel the old fluid from the caliper. Never push the old, dirty fluid back through the system and into the ABS unit or master cylinder.
    ...and much more that I'm too lazy to post on here.
    I LOVE TECH ARTICLES! :D
  2. LVT
    LVT Well-Known Member
    t3h f4sT
    thanks the the articles, good reads!
  3. dezavu
    dezavu New Member
    At a friendly psyche ward near you
    you never knew this? :roll:
  4. kickin_81
    St. Paul
    ^^ no. :roll: :lol:
  5. esperunit
    esperunit Well-Known Member
    Paris, 7eme Arrt.
    so then, what kind of oil do you run in the winter?
  6. kickin_81
    St. Paul
    Me? Amsoil 5w30. :) In comparison to the others, it has a really high viscosity index and really low pour point: both needed to make a great winter oil.
  7. dezavu
    dezavu New Member
    dude, i could've told you all this info... i thought it was common sense to bleed your old fluids out when changing even just your brake pads... i always buy new fluids and refill things up.
  8. kickin_81
    St. Paul
    I don't think it's always necessary to bleed your brake fluid the same time you do your pads. It's two similar jobs; not the same job. What I just learned is that in those occasions you just need to change the pads, do not c-clamp the piston back into the caliper because it forces fluid back through the brake system. Not good since the brake system only flows one way; will never happen again. ;)
  9. Zola
    Zola Well-Known Member
    St Louis Park
    ugh @ which oil is better wars
  10. wall of tvs
    dream ftw
    Crisco for teh win!!!!!eleventy!!!!!1
