Ratchets/Sockets/Wrenches
Discussion in 'FS: Everything else' started by Shancaldazar, Feb 14, 2013.
  1. Shancaldazar
    I've got several different things up for sale that I would like gone!!! They are just taking up room in my toolbox. PRICES ARE NEGOTIABLE. Shipping is not included. Make me a reasonable offer and see what happens.
    I've some 3/8 drive ratchets first of all. All come with a 5/8 socket. They are short, with a knurled handle, and 36 teeth. They have an "ING" logo (the letters ING with small lion) on them that is starting to peel off, but the chrome beneath is fine. I have 35 of these that have never been used.
    $5 each-I want them out of here!
    Then I've got a 9 Piece metric combination wrench set (12 point box end and open end). $5for all of them: 6,7,8,10,12,13,14,17,19MM sizes. Only the 19MM one has been used.
    Kobalt Dual Drive 3/8 ratchet. Can be used as a normal ratchet or you twist the handle to continue to turn the socket. Also has extendable handle. 72 teeth. $10
    6 Piece Kobalt Universal Socket set that are 3/8 Drive. These sockets double as both metric and SAE, along with 6, 12 point, spline and multiple other types of bolt heads. Lifetime warranty at Lowes. Never Used. 5/8 (16MM), 9/16 (14MM), 1/2 (13MM),7/16 (11MM), 3/8 (10MM), 5/16 (8MM) $10
    A 27MM 12 point sockets (1/2 drive) from Kobalt with lifetime warranty at Lowes. $5. Used once each. Note: No damage, that is just reflection on it.
    22MM 6 point impact socket, Kobalt with lifetime warranty at Lowes. 1/2 drive and $5 for it. Used once.
    11MM 6 point 3/8 drive kobalt impact socket with lifetime warranty at Lowes. $1 or free with the purchase of anything else! Used once.
    7 Piece Kobalt metric hex bit socket set with 10MM, 8MM, 7MM, 6MM, 5MM, 4MM, 3MM. 3/8 drive. Only used 2 of them two or three times. They do have several spots of rust on the actual hex bit part despite being oiled (typical of these hex bit that have a high amount of carbon in the steel, and high carbon is good for strength). The 6MM hex bit has some damage to the chrome. $10 for all seven!
    Rust shot
    Damage to the H6 chrome. Not bad at all.
    Then also a Carlyle (Napa's professional brand, who makes some great pieces) Hex bit socket in 10MM size. Never used, but has a little rust despite being oiled again. 3/8 drive. It is longer than the Kobalt ones above. $5 OBO
    Some Harbor freight 1 piece hex bit socket set. 6 pieces size 17MM, 14MM, 12MM, 10MM, 9MM, 8MM. They were part of the drain plug socket set, but I've got other hex bit sockets that I use so these can go up for sale. $5 for all of them.
    9 Piece set of Dual position socket extensions from Northern tool (made by Danaher, AKA Gearwrench). (3) 1/2 drive, (3) 3/8 drive, (3) 1/4 drive. These are unique- they can be used as both regular extensions, and wobble extensions, depending on if you push the socket on 1 click or 2. $20 for all + Shipping!.
    6 Piece set of harbor Freight screwdrivers. They have magnetic tips in them. $2 for them.
    Snap Ring pliers. Nothing fancy, but if you need some cheap ones for a single use-here ya go! $5 for an inny and an outty with sets of bits.
    Armstrong 3/8 Drive 8MM deep 12 point socket. Quality USA piece, with nice chrome and finish. $5
    Evercraft o2 Sensor socket 7/8 (22MM) socket size. This is what fits Subarus to remove those stuck o2 sensors. $5
    Evercraft flex Spark plug socket (whatever size is used on Subarus). 3/8 drive and I've used it once for a spark plug change (4 plugs). The flex makes it much easier to reach spark plugs on the boxer engine. $5
    Shipping extra. For multiple items I will send it via USPS Flat rate boxes. Individual ratchet/socket purchases will be sent in a padded envelope.
  2. Shancaldazar
    Forgot to mention that the Kobalt sockets (lowes), Titan Flex (northern Tool) wrench, cheap wrenches (home depot) and craftsman sockets (sears) all have a transferable Lifetime no questions asked warranty.
  3. Shancaldazar
    BUMP! Buy my stuff up!
  4. Shancaldazar
    Also adding some craftsman 12 point metric wrenches for sale! 6MM to 18MM (no gaps). Some are newer Forged in the USA ones bought to fill in the set, others are older unmarked wrenches (not sure of COO). All have a lifetime warranty however at sears. 13 piece set for $35.
  5. Shancaldazar
    Craftsman metric wrenches SOLD. Everything else is still up for sale. Also have a 22MM 1/2 Drive Kobalt Impact socket up for $5, and $2 for an 11MM 3/8 drive impact socket.
  6. Shancaldazar
  7. Shancaldazar
    Got some nice tools in here for sale! And then some cheap ones you won't feel bad abusing for a great price!
  8. Shancaldazar
    Bump! Prices very negotiable!
  9. Shancaldazar
    I'm adding an Evercraft (napa brand-lifetime warranty) 3/8 click type Torque wrench (5-80 FT-lbs, and the industry standard accurate from 20% to 100% of scale, or 16-80 FT-lbs from the factory) for sale. It also has newton meters on it. Just calibrated/tested it myself by doing 5 on each ft-lbs setting (after a few to warm/lubricate the system) pulls and using a shipping scale I know is accurate. This wrench is rated at an accuracy of either 4% or 5%, which is basically what you get for a cheap torque wrench (snap on is around 2-3% for click type).
    Results were:
    @70 FT-lbs-72.7, 71.8, 72.3, 72.0, 71.2. All are with in 3.8% and were consistent.
    @50 FT-lbs-50.2, 50.7,50.2,49.5, 51. All again are withing the acceptable margin of error and consistent.
    @35 Ft-lbs-35.7, 35.0, 34.5,34.8,35.3. Again all good.
    @20 FT-lbs- 16.8, 17.2, 16.4, 16.6, 16.9. This is fairly inaccurate, so if you want a good torque wrench for low torque applications, don't get this one.
    $30 brand new, so $15 picked/meet up. Will not ship this unless you understand that shipping will most likely change the calibration.
  10. Shancaldazar
    $25 For a 1/2 Drive Evercraft Torque Wrench. Well within calibration, accurate from 40 to 150 FT-lbs when I tested it. I can post up the actual numbers I got if anyone is interested.
  11. Shancaldazar
  12. Shancaldazar
  13. Shancaldazar
  14. cloudpost
    cloudpost Member
    Thanks for meeting up with me so late last night. Got a cheap starter tool set for my GF's new place!
  15. Shancaldazar
    Bump!!!
    HF screwdrivers, spark plug socket, Kobalt ratchet, and Kobalt universal socket set sold (individual sockets still available).
    First one to give me $75 bucks for the 35 ratchets gets em all....
    Seriously make me offers on the rest. I really want to get rid of it now.
  16. Shancaldazar
  17. Shancaldazar
    14 Piece Craftsman Metric Set (12 point). Sizes 6MM to 19MM with no skips. Lifetime warranty (no receipt needed) at Sears. Used a few times but in brand new looking condition.
    12 piece SAE Craftsman Wrench Set (12 Point). Sizes 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16 and 7/8 in. Lifetime warranty at sears again (no receipt). Brand new. Will not include the factory packaging to save $15 on shipping.
    12 Piece SAE Craftsman wrench set (6 point). Sizes 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16 and 7/8 in. Lifetime warranty at sears again (no receipt). Will not include the factory packaging to save $15 on shipping.
  18. Shancaldazar
    10 Piece Gearwrench SAE Ratcheting Wrench Set. Sizes 1/4",5/16", 3/8", 7/16", 1/2", 9/16", 5/8", 11/16”, 3/4", 13/16” and lifetime warranty.-$50
    10 Piece Gearwrench Metric Ratcheting Wrench Set. Sizes 8MM, 9MM, 10MM, 11MM,12MM, 13MM, 14MM, 15MM, 16MM, 17MM and lifetime warranty. $50
    Carlye (Napa Professional line of tools) Flare nut wrench. Sizes 10MM and 12MM in one wrench, so it works for any Subaru (10MM was pre VDC, and 12MM is VDC). $10 with lifetime warranty at Napa
    Snap On 19/21MM in one flare nut wrench. $30
    Kobalt 4, 4.5, 5.5, 4.5 deep and 5.5 deep sockets. 1/4 drive and lifetime warranty. $5
    Also got some HF socket storage trays. Both SAE and Metric. Free for anyone who wants to pick them up. They have a couple of the pegs broken, but still hold sockets.
  19. Tim
    Tim Member
    Where are you located at? I'd totally come take a look at some stuff. Great prices!
  20. Shancaldazar
    I'm located in Plymouth. Send me a PM if you want to swing by.
  21. Shancaldazar
    BUMP!!!!
    THIS IS WHAT I HAVE LEFT!!!
    Then I've got a 9 Piece metric combination wrench set (12 point box end and open end). $5 for all of them: 6,7,8,10,12,13,14,17,19MM sizes. Only the 19MM one has been used.
    A 27MM 12 point sockets (1/2 drive) from Kobalt with lifetime warranty at Lowes. $5. Used once. Note: No damage, that is just reflection on it.
    Rust shot
    14 Piece Craftsman Metric Set (12 point). Sizes 6MM to 19MM with no skips. Lifetime warranty (no receipt needed) at Sears. Used a few times but in brand new looking condition. $35
    12 piece SAE Craftsman Wrench Set (12 Point). Sizes 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16 and 7/8 in. Lifetime warranty at sears again (no receipt). Brand new. Will not include the factory packaging to save $15 on shipping. $30
    12 Piece SAE Craftsman wrench set (6 point). Sizes 1/4, 5/16, 11/32, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16 and 7/8 in. Lifetime warranty at sears again (no receipt). Will not include the factory packaging to save $15 on shipping. $30
    Also the SAE sockets trays are here, but not the metric.
  22. Shancaldazar
  23. Shancaldazar
    $10 takes ALL the hex bit sockets (7 kobalt, 6HF, and 1 Carlyle)!!!!
    $5 Takes the 11MM socket, 22MM socket, 27MM AND the Wrench set!!!
    $25 for each Craftsman Wrench set!!! $60 takes all 3!!!
    $50 for each ratcheting gearwrench wrench set!!! $80 takes them both!!!
    $10 for the Carlyle Flare nut wrench!!!
    $25 for the Snap On Flare nut wrench!!!
    Ratchets with the 5/8 socket are now FREE (will not ship even for cost of shipping).
  24. Shancaldazar
    $5 Takes the 11MM socket, 22MM socket, 27MM!!!
    $25 for each Craftsman Wrench set!!! $40 takes both!!!
  25. Shancaldazar
    BUMP!!!
    These are now added!
    6 Piece pin Punch set from bostitch (100 year warranty at any place that sells them, they are a few month sold, so the warranty is still good!). $5 Great for removing roll pins from axles and shift linkages. One is a little bent, but can be bent back (or warrantied if you so desire), but the appropriate sized ones for Subaru's are in great condition, just never bothered to get the bent one replaced because I never use it!
    Harbor Freight long pin punch set. Same use as above, just longer to reach pins that are in hard to reach spots! $5, never used!
    CV Boot clamp tool. This is for CV boot clamps that the end of the clamp snaps onto the clamp itself (not the "dual banded" ones where you tighten the outer band, which in turn squeezes the inner band), then get this "crimper" to full tighten the boot. $5
    A 17MM magnetic drain plug socket! Sized for Subaru drain plugs (17MM) and magnetic with a "speed ring" (allows greasy fingers to grip the socket and turn it by hand). This will prevent you from dropping the drain plug into the oil pan because it is magnetic. Also attaches to any 3/8 drive ratchet or if you have a craftsman/geawrench pass through socket wrench, it can be used with that too! Must have for Subaru Oil changes! $5
  26. Shancaldazar
  27. Shancaldazar
    Bump! I want to get rid of this stuff!
  28. Shancaldazar
    I'm at college so I currently don't have access to any of this to ship it. If you are interested, feel free to ask as there may be times where I am home and able to ship (I am 50 minutes away from my house).
    Plus I'll be adding some cool (read: more useful) stuff in the near future!
  29. Jim
    Jim Well-Known Member
    I'm interested in the snap ring pliers, drain plug socket, o2 sensor socket, maybe metric ratcheting wrenches if the price is flexible on them. PM me if you'll be in town anytime soon.
