Rattle from short shifter
Discussion in 'Modifications And Maintenance' started by Underhill, Dec 23, 2006.
  1. Underhill
    Underhill New Member
    My shift lever has started to rattle some, mostly in 3rd 4th and 5th I think. but it does it an most gears. Not all the time, but alot. Any ideas what it would be? 04 Sti, unsure of what kind it is though, so no help there, sorry. If I hold the shifter lever I can make it stop, so Im guessing its not down inside but at the lever somewhere?
  2. Xcelor8
    Xcelor8 Well-Known Member
    Are you sure it's the shifter, do you have an aftermarket Downpipe, downpipes have been know to rub a little.
    Never noticed your location before, you must be in Valley Park, that's where I grew up. Parents Still live there, so I'm there quite a bit, but I'm on the other side of the town now.
  3. Underhill
    yep I do have a DP, but when I hold the shifter lever when its ratteling, it stops, so its nothing down lower I don't think.
  4. Sogonerg
    Sogonerg Anteater
    bushing?
  5. TSTRBOY2004
    might wanna check all the nuts etc... if it rattles soemthings probably worked loose...
  6. stoooo
    stoooo Well-Known Member
  7. kickin_81
    kickin_81 Well-Known Member
    My Cobb short shifter rattles against the metal ring of the shift boot when I travel 65+mph. When I hold the shifter or that ring, the vibrations/tapping is deadened. Is that what the issue is with yours too?
  8. Bullwinkle
    Yeah. Guessing if you didn't install it, you don't know if they added aftermarket bushings. I'd vote for that as the cause.
  9. Underhill
    Im not sure what is making the noise yet, having a 10mo old kinda eats up the free time, holidays etc... But its been getting worse, it now really sounds like something is loose in there. I need to check it out soon I guess.
  10. Underhill
    well :hsugh: its a Cobb short shifter :biggrin: . and the rattle was from the shifter trim retainer nuts...two were loose, one nut was down in the grease by the bottom of the shifter. I haven't taken it for a drive yet, but I almost sure thats what was causing the rattle.
  11. Underhill
    that was only part of the rattle, I need to pull off the plate thing under the plastic and trim the corner the (linkage?) is rubbing in 1st 3rd and 5th. At least now I know what it is. Still might buy some new bushings.
  12. DISCOPOPE
    DISCOPOPE Well-Known Member
    on my suby dude shifter the reverse lockout boot rattles on the shaft.
    i 'think' the cobb one is similar.
    i was going to take mine apart and put a length of heatshrink on the shaft.
