rear diff (?) issues? halfshafts?1!
Discussion in 'Modifications And Maintenance' started by DISCOPOPE, Aug 3, 2005.
  1. DISCOPOPE
    DISCOPOPE Well-Known Member
    ok, so i've been getting a clunk on the rear of the sti.
    it happens over bumps, on cornering, and on acel/decel. i assumed that it was a sway bar or one of those arms down there so i made an apointment to have it looked like and started convincing my wife how i should get the hotchkins street kit. :)
    well, it's progressively worse, so bad that i invisioned the rearend dropping out on the freeway..
    with a my apointment not untill next week, i decided to put it on the ramps and go underneath to try and find the problem.
    nothing is lose.
    endlinks, swaybay, those arm thingies, nothing..
    i start looking at the diff, and the pass side has a coating of oil on it. i grab the pass side shaft and give it a tug. clump clump..
    i tug on the drivers side, ... clump clump...
    question #1 is it reasonable to assume that i have borked half shafts?
    question #2 what is the probability that this could happen without any signifigant launching? could daily driving at 280whp do this?
  2. jNorthWRX
    jNorthWRX Well-Known Member
    Blaine
    uh ohhhs!
  3. AWDimprezaL
    Monticello.
    warranty is t3h win
  4. Grimm
    Grimm New Member
    I have never had warrenty work, and Morries hasn't even goten back to me after their missdiagnostics of my Alt.
  5. esperunit
    esperunit Well-Known Member
    Paris, 7eme Arrt.
    another theory:
    you have a bad strut. Happens all the time on STis. I have had the same problem, along with 2 other people I know.
    If you want me to listen to it, I can verify for you. I know the sounds all too well.
    And don't drive on it more than you have to, you can lose your CV if it bottoms, adding a good 1k in repains/work to the damage. If this is the case then the fluid could be axle grease... It can fly quite a ways inside there
    anyways, I can take a look for you. I've seen the strut problems before
  6. bikerboy
    on the water looking for the sandbox
    IIRC there is a TSB that the top hats are bad on early sti's
  7. DISCOPOPE
    thanks guys,
    i will keep you updated.
  8. Dream
    south
    strut tops i bet
  9. DISCOPOPE
    UPDATE:
    both rear struts were bad.
    getting replaced under warranty.
    /cheers
  10. esperunit
    Paris, 7eme Arrt.
    yay. I called it.
    this is the 4th time I hae seen this happen to a car I know. thank god for v7 tops.
  11. DISCOPOPE
    yep, good job man.
    i crawled underneath the thing and could'nt figure it out!
  12. Dream
    south
    Well I have a bad strut also!!! DAMN!! Its getting really bad now too, im not sure im going to drive it much untill I can get a replacement :(
  13. esperunit
    Paris, 7eme Arrt.
    If you keep driving it at your ride height, you're going to need the number of my axle replacement guy. I'd not drive it at all if you want to keep the CV on the side its on.
    The strut problem is becuase of the version 8 tops. I really don't know STi owners who havent gotten it.
    I wonder if reverting to an STi ver 7 setup would help. I only blow front sturts.
  14. Dream
    south
    I know, I just dont have anything to drive untill monday and the strut will be here 1 week from today.
  15. morganm
    morganm New Member
    A small mount of play in your axle shaft assemblies is normal. This is due to your DOJs. You mentioned oil all over back there? Perhaps a torn boot on a DOJ? Was it thick, booger like, bearing grease (used to pack yoru CV and DOJ boots); or thiner like gear oil from the diff?
  16. DISCOPOPE
    definitly a thin oil, right on the side of the diff.
    not a grease at all.
    i just had the 30k service done, which includes a diff service. i'm still not 100% thinking all is well. after the struts are replaced i'll clean it off really well and look for new leakage.
  17. morganm
    morganm New Member
    There is a seal on the outside of the carier. Might be sweating some gear oil :(
