Rear wiper not working in 93 impreza
Discussion in 'Modifications And Maintenance' started by midcoat, Oct 23, 2009.
  1. midcoat
    midcoat Member
    Just notice that my rear wiper for my 93 impreza ls wagon is not working. Is there a fuse for it? Looked under the hood in the fuse box but said nothing in regards to the rear wiper.
  2. AWDimprezaL
    Check for power at the motor itself.
  3. errorcode3
    errorcode3 Member
    i would also be looking at the motor, either its not getting juice (or grounded), or the motor itself is dead. and did this just happen since its been raining today?
  4. midcoat
    midcoat Member
    I'll have to check and see when I get off, just bought the car not to long ago
  5. phi11
    there should be a fuse, a relay, and a switch,
    add those to the list of problems that it could be.
  6. midcoat
    midcoat Member
    Where would the fuse be located? I look on autozone's repair guide and after taking off the rear panel I can access the motor, but I rather not if I dont have to.
  7. Frogy
    Frogy Well-Known Member
    This may or may not be appicable, but I had a real hard time when I was trying to work on the rear wiper on one of my grand cherokee's, it turned out that if the hatch wasn't closed totally the wiper would not even get power. so if the wiper doesn't get power it might not be a bad idea to look for a switch?
  8. 02blubru
    would the fuse be under the dash to the left of the steering wheel closest to the drivers door?
  9. Aegis
    If all else fails, I actually bought one of these for my old wagon - same year as yours, and never installed it. IF - and this is a big IF - I can find it, I'll let you know. It may have been given to Colin, if it wasn't ... it's in the garage ... *scared look toward the garage* .. with the mess.
  10. AWDimprezaL
    That brings up a good point, Ive seen more then one impreza wagon that had the harness starting to get broken in half up where it goes into the door.
  11. Chux
    My 4runner has this as well. but AFAIK not on any subarus.
    can you hear the motor running? the rear wiper mechanisms have plastic gears that are prone to stripping out.....the electrical part could be fine, but the mechanism is shot.
  12. 95lwrx
    95lwrx Well-Known Member
    i would go with this, happened on one of mine, several of the wires were broken from wear and tear
  13. greg donovan
    ditto. broken wires in the harness between body and hatch is the most likely culprit.
    mine wont "park" so i have to pay attention and try and catch it when it is down if i dont want it stopped in the middle.
  14. delubs
    delubs Active Member
    I'm dealing with this problem right now. The previous owner also cut the rubber wire cover/gasket in half so water is now leaking into the back of my wagon :(
