Recent talk on nasioc
Discussion in 'Vendor Announcements/Sales/Discounts' started by AWDimprezaL, Jan 18, 2008.
  1. AWDimprezaL
    Got me to thinking, why people are selling used sti transmissions for so much money (5K+!) when you can get a brand new 07 sti trans for the MNsubaru price of $3904.00, PM me with any questions.
  2. AspitFire
    glad i could help :)
  3. AWDimprezaL
    WORD forgot to mention, josh pointed it out to me.
  4. AspitFire
    wonder where the guy got the quote for $3500, thats a killer deal
  5. blackozone
    Are you talking a full swap for a WRX or just the transmission?
  6. AspitFire
  7. AWDimprezaL
    Full trans, all you would need would be axle stubs, automatic trans driveshaft and a 3.90 rear diff
  8. curly2k3
    broken nasioc link btw
  9. Iroc-Z
    Iroc-Z Well-Known Member
    Sti transmissions suck
  10. AspitFire
    updated the link
  11. yangsTa
    yangsTa Well-Known Member
    Link not workin.
  12. AspitFire
    :biggthumpup:
  13. esperunit
    esperunit Well-Known Member
    holy crap.
    Let me go sell a kidney real quick.
  14. AspitFire
    quoted off the thread
    Okay guys.
    ANYONE that wants the same 2007 STi transmission that I got can get it for....
    ****drumroll*****
    $3750
    PM thekingofparts and talk with Tristan.
    Keep in mind that this is for the Transmission only. All that comes with it is the gearbox, a new clutch cylinder, throw-out bearing, shift fork, DCCD and wiring on the trans side only.
    If you have any question as to what is needed for a 2002-2005 WRX pm me and I can get part numbers for you. 2006-2007 owners will need a little more. I'll post up a new thread with all the info when I get a chance.
    [​IMG] [​IMG]
  15. AWDimprezaL
    i dont know right now if we can match THAT price, but i will talk to the manager
  16. Scuba Steve
    Wow, just wow! good prices
  17. AspitFire
    so now the question is, why is the '07 sti transmission cheaper then previouse years? i think like $1200 cheaper. What did they skimp on? or what did they change? or did they just get a hellova deal on the manuf process?
  18. 1_sic_rex
    1_sic_rex Well-Known Member
    Those are some good prices for sure.
  19. Paul Revere
    Now what do you think about doing an STi tranny?
  20. AWDimprezaL
    i dont really know, but i do know the 07 has better gear ratios
  21. AspitFire
    i just hope they didnt skimp on anything
  22. Justin
    Justin Well-Known Member
    nice find josh! might be doing this when the wrx tranny goes
  23. AspitFire
    yes, this def closes the gap on the PPG vs STi gear set
  24. 02blubru
    would the sti trans swap be a good gear ration match for a wrx with the 2.0l?
  25. curly2k3
    yes, it would be awesomeness billiam
  26. 02blubru
    thats what I was thinking?? so how much to do the whole swap??
  27. curly2k3
    yeah AspitFire what else did you have to pick up? Bill i would be game to help out
  28. 02blubru
    sweet thanks, let me know when you get all the parts. lol:cool:
  29. curly2k3
    psh, if i had the parts i wouldnt NOT have an auto in the wagon
  30. AspitFire
    I dont know the for sure answer, but this was taken from that same thread on nasioc
    -transmission
    -driveshaft
    -6 speed shifter and assembly****
    -6-speed clutch fork and slave cylinder for 2007 sti
    R160 rear diff (02-05 wrx)......(i thought you needed a r180 rear diff with axles?)
    6 speed clutch and flywheel
    Circlips from 2004 sti
    DCCD wiring
    slave cylinder
    DCCD box, or spider unit, or simialar programmer
    "the only way to get FULL functioning dccd is to swap in the dccd computer and abs unit from an sti along with the rest of the sensors."
    again this was all taken from that thread with the same people asking the same question.
  31. Justin
    so now the question...wray/chux, can you wire in dccd?
  32. Chux
    wray's done it.....I've got diagrams, for whatever that's worth
    but, as you'll notice in the above list, doing it with the stock controller isn't an easy project. talk to piddster about aftermarket controllers, he's researched them, and has one in his car.
  33. 02blubru
    do you have to have the dccd? and a newb quesiton here, what does it do and at what time would you use it?
  34. Justin
    what if no dccd but you want to control when the center diff opens?...wonder if thats easy.
  35. AspitFire
    If no dccd is ran, the diffs will run open
  36. piddster
    Unless subaru changed it, you can use any turbo slave on the 6mt. I have a WRX unit with a Legacy SS master.
    Axle stubs - 38415AA110
    circlips 805329010
    These are what I used to put the 6mt in my car. If your axels have the stubs machined as part of them, you just need the seals, AFAIK.
    You don't need an R180, just a rear diff with a 3.90 ratio. I'm using one out of a '92 Legacy Automatic untill I put this 3.90 VLSD back together from, I think, a '99 Impreza.
    Center diff isn't nessecarily "open" but with the torque bias, it will feel as if it is. I'm using Spiider's auto controller, and its well worth it. Mush simpler to install, and it very effective. It has a high resolution 2 axis G sensor and a TPS input. It uses several modes of logic as opposed to lookup tables like other aftermarket units. The auto unit also has a thumbwheel to set the "agressiveness" of the controller. People have even used it in rally and have been happy with it.
  37. piddster
    Yeah, I'm retarded for buying this garbage:roll:
    If all you're worried about is frumrolls, don't get it. For everything else, its worth it.
  38. driftin240
    driftin240 Well-Known Member
    God Piddy, your so stupid. You bought one of the greatest transmissions of all time. Whatever made you do something so dumb???
    LOL
  39. piddster
    Fixed that for ya ;)
    I guess I'm an impulsive buyer :dunno:
  40. AWDimprezaL
    the catalog says the sti rearend is a 3.54 ratio for all years, whats up with that?
  41. Chux
    the front axle ratio is 3.545, but after the 1.1:1 transfer gear, the rear axle ratio is 3.90
  42. Ej22TIM
    Ej22TIM Well-Known Member
    ughh I wish I had the cash. I need a trans bad.
    Rebuild 1.8 trans? (only to have it blow again?)
    6 speed?
    Wrx?
    I can has Money Tree?
  43. AWDimprezaL
    when i go into rear end it says that.....i'll take a screenshot monday
  44. piddster
    Hmmm, wierd. I thought it was common knowledge that the rear was a 3.9.
    Mine hasn't gone *munch* yet so it must be correct.
  45. AWDimprezaL
    i totally agree, you are living proof, but i doubt it would be wrong.....
