Redline Oils now available at GrimmSpeed
Discussion in 'Vendor Announcements/Sales/Discounts' started by Justin, Oct 5, 2007.
  1. Justin
    Justin Well-Known Member
    St. Paul, MN
    GrimmSpeed is now officially a Redline Oils dealer! Redline is a leader in the engine oil and gear lube industry so we are proud to be able to provide you with their products.
    Right now we have the following in stock:
    Redline Lightweight Shockproof Gear Lube $10.99
    http://www.grimmspeed.com/catalog/product_info.php?cPath=31&products_id=69
    A unique lubricant containing a suspension of solid microscopic particles as an extreme pressure agent--unique solid dispersion which cushions gear teeth to help prevent tooth breakage and allows the use of lower viscosities.
    Acting like a liquid grease, the viscosity characteristics of ShockProof® allow the lubricants to resist throwoff and provide the protection of a greater film thickness with relatively light fluid viscosity, offering a "best of both worlds" balance of low drag and superior protection.
    Redline 75W90 Gear Oil $9.99
    http://www.grimmspeed.com/catalog/product_info.php?cPath=31&products_id=68
    Designed to provide the highest degree of protection and greatest efficiency for your drivetrain. Red Line provides a complete line of drivetrain lubricants which are optimized for differential, transmission, or transaxle use over a wide range of temperatures. Proper selection depends upon the manufacturers' requirements and whether the application is for passenger automotive, commercial, or racing use. Red Line Gear Oils contain polyol ester basestocks to provide excellent lubrication even under extreme conditions of high-loading and high- temperatures--their natural lubricity provide excellent slipperiness which reduces the sliding friction in hypoid gears to reduce wear and temperatures. The synthetic basestocks have a natural multigrade property, so large amounts of unstable thickeners are not required to manufacture our gear oils, which means that Red Line Gear Oils will provide a stable viscosity for even extended periods of use. Red Line also manufactures gear oils which can be used in limited-slip differentials without the use of additional friction modifiers.
    Redline WaterWetter Coolant System Additive $8.95
    http://www.grimmspeed.com/catalog/product_info.php?cPath=31&products_id=67
    WaterWetter® is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30ºF. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass and bronze systems. Compatible with all antifreezes, including the latest long-life variations.
    Check out the WaterWetter Demo:
    Click Here: http://www.redlineoil.com/products_coolant.asp?subCategoryID=4&coolantFlash=1]
    Redline SL-1 Fuel System Cleaner $7.95
    http://www.grimmspeed.com/catalog/product_info.php?cPath=31&products_id=70
    SI-1's injector and valve detergent is a concentrated package of the most powerful high-temperature detergents available to clean gasoline fuel injectors or carburetors, intake valves and combustion chambers and can clean injectors to nearly 100% efficiency in one treatment. The cleansing effect on injector deposits can raise fuel economy approximately 12% or even greater, depending on the condition of the injectors.
    SI-1 also contains detergents and a synthetic upper cylinder lubricant which will help clean pollution control valves and can reduce octane requirements by two numbers. SI-1 also protects the fuel system from rust.
    Redline WRX PowerPak $99.99
    http://www.grimmspeed.com/catalog/product_info.php?cPath=31&products_id=66
    Included in the kit are 5 quarts of 5W30 motor oil, 4 quarts of 75W90 NS gear oil for the transaxle, 1 quart of 75W90 gear oil for the rear differential, 1 bottle of WaterWetter for the radiator, 1 bottle of SI-1 Complete Fuel System Cleaner, a sticker kit and a Red Line Oil embroidered hat.
    We can get anything else that Redline carries as well....all you have to do is ask us!
    Justin Grimm
    www.grimmspeed.com
    AIM: GrimmSpd
  2. Nuke
    Saint Paul
    Yes, Redline, whoowhoo
  3. bummpy
    bummpy New Member
    nordeast
    I need to get my cocktail on.
    I might be stopping by soon. Possibly today?
    You gonna be around between 5 & 6 today?
  4. Justin
    St. Paul, MN
    i'll be around till mid day...in a wedding this weekend so tonight and tomorrow are shot.
  5. bummpy
    bummpy New Member
    nordeast
    no worries. Maybe sometime next week.
  6. Aegis
    Female
    サイレントヒル
    uh ohs ... I forsee this being very good :)
  7. Bielke55
    Hopkins
    [offtopic]open bar?[/offtopic]
  8. readymix
    Eloh, El
    I need 4qts of 75w90ns ;) oh, and one of the 75w90 for the diff. Price?
  9. LSE Performance
    LSE Performance New Member
    Ramsey, MN
    Are you guys going to be carrying the full line as well?
  10. Sogonerg
    Sogonerg Anteater
    Earth
    Big thumbs up Justin ;)
  11. TSTRBOY2004
    I am guessing he answered that question!?!?!?!? well kinda.. right now he said thats what they stock... but can get ANYTHING ELSE... probably not carrying it all ???
  12. Justin
    St. Paul, MN
    We now have the following Redline products in stock:
    Redline 75W90 Gear Oil - Quart
    Redline 75W90NS Gear Oil - Quart
    Redline MT-90 Manual Tranny Oil - Quart
    Redline Lightweight ShockProof Oil - Quart
    Redline HeavyWeight ShockProof Oil - Quart
    Redline Sl-1 Fuel System Cleaner 15oz
    Redline WaterWetter - 12oz
    Redline D4 Automatic Transmissin Fluid
    Redline 5w30 Synthetic Engine Oil
    We are also now accepting VISA, MasterCard, Discover, and AMEX.
    Thanks!
    Justin
    www.grimmspeed.com
    [email protected]
    AIM: GrimmSpd
    PHONE: 612-481-5731
  13. prezawagon
    prezawagon Well-Known Member
    Redmond
    What's your address and hours? I looked around on your website but didn't find it. I need to swing by there sometime and pick up a quart of lightweight shockproof.
  14. GrimmSpeed
    GrimmSpeed Vendor
    www.grimmspeed.com St. Paul, MN
    address is on the homepage on the left. it is:
    261 Richmond St.
    St. Paul, MN 55102
    Right now we dont have any typical hours, just PM us or call us(612 481 5731) and we can make sure someone is there.
